Results 1 to 10 of 19
    Jun 2013
    Default Yearly maintenance / winterization
    Being a new OBV (and inboard) owner I'm curious what everyone thinks is necessary end-of-the-season maintenance that is different than what the owner's manual calls for? What is needed in the first year (I should have right around 25 hrs at the end of the season) vs. every year after the first?
    I have asked the same question of my dealer and so far they have been great to work with, but I would like to come into the discussion with them as intelligent as I can since I'm not much of an engine guy.
    And as far as winterization goes, what is the general thought on inboards about either using antifreeze or just draining all the water from the engine? The dealer/shop I used for my old I/O swore by just draining the water and I never had an issue after 10 yrs but I'm not sure if that thought process holds true with inboards. My boat is stored in non-heated storage in IL during the winter so we can definitely get below zero temps.
    Welcome any and all of your thoughts.
    Mike
    2013 Outback V
    - FAE
    - DIY suckgate
    colorado
    Now this is a painful topic to bring up in August. there is a great writeup in the how to section by Al cab.. something. sorry al, im not here enough to remember your name. but he has tons of pictures and instructions. he has an LSV, but for most of the info for your OBV, i think is probably similar.
    but winterize for certain, and remember to drain the heater core too.
    08 LSV
    Mar 2012
    South Carolina
    First year I used antifreeze. Every year thereafter I did not. If you have access to an air hose just spray out your ballast lines and all with air after you've pulled them to drain, and as mentioned before be sure to drain your block.
    Ugh, this post reminds me that fall is coming and that means boating season is nearing an end in a few months.....
    Jun 2013
    Quote Originally Posted by yearround View Post
    Yeah, sorry about that, I guess I could have at least waited until after Labor Day...
    I did see that post on the winterizing and will certainly be referencing that when the time comes -- I was really more interested in what everyone thinks about whether antifreeze is needed or not.
    Please keep the comments coming, I'm interested to hear what everyone does for "normal" yearly maintenance as well.
    Thanks.
    Mike
    2013 Outback V
    - FAE
    - DIY suckgate
    Boooooooooooooooooooooooooooooooo! Don't use the evil *******nterization word around here in August!
    At the end of the day yesterday on the way in I did notice the air slightly cooler than usual. Uh oh. Football is starting too. Our season goes till Halloween so I'm not too worried yet.
    Jun 2013
    Here in the midwest my boat is usually already in storage for the winter come Halloween and I'm really lucky to get any time on the water after Labor Day. With the kids back in school and my son playing football on Friday nights that really hampers the lake time. I keep telling the wife we need to move to a warmer climate!!!
    Mike
    2013 Outback V
    - FAE
    - DIY suckgate
    Lake Point UT....
    the years I had the dealer winterize, they do antifreeze and I was told by both it's part of the process. I winterized the supra myself 4 of the 5 winters and didn't use it. I keep my boats in an insulated garage(no heat) so they stay around 50deg or so. no need for antifreeze but your storage needs may be different. It's really not important to get every drop of water out of the boat as all you want is enough room for expansion should the worst happen and it does get exposed to freezing weather.
    this is all imo and take it fwiw. others will have differing opinions and I would say do what makes YOU comfortable.
    I too store mine in an insulated garage, but have heat available if it gets too cold (usually doesn't drop below 50 in there). I never use antifreeze, I actually do nothing special for winterization except make sure I stabilize the gas.
    As for changing fluids on a yearly basis, do most do that at the end of the season or the beginning of the season? I usually do at beginning, but was curious.
    06 Mobius LSV, GIII (now with 1100 in the port locker), perfect pass, wakeplate
    Kicker KM10 Sub, dual batteries
    Des Moines, IA
    I drain and then do antifreeze since it's only $15 and makes me worry less. Plus the antifreeze is supposed to help with corrosion prevention. Don't think it's a big deal either way, as long as you get the water out.
    Des Moines, IA
    Definitely change oil at the end of the season. You don't want old oil sitting all winter.
