Results 1 to 10 of 11
Thread: Prop question
    May 2011
    Fort Worth
    Default Prop question
    Hey yall, I have the stock porp on my '08 LS, would changing to this one be any real improvement?
    http://www.wakeprops.com/acme-515-propeller.html
    Thanks, Casey
    P.S. What size shaft on my boat? '08 Mobius LS.
    '08 Mobius LS
    Is your stock a 13 x 13? What are your goals? More low end pull?
    May 2011
    Fort Worth
    13x11 1/2 Afriend offered it to me for almost mothing. I was just wondering if it would be worth the labor.
    '08 Mobius LS
    Zegm who used to come on here and had your boat went to, I think, an ACME 13x12 4 blade and loved the results. I'm not sure you would see much difference with just a little bit of pitch difference. The "new" prop might have a little more top end and a little less low end pull because it is higher pitched. But, depending on the cupping of the two props the difference might not even be noticeable. Do you have a spare? You could swap and see what you like better and keep the other for a spare. Never hurts to pick up a cheap spare.
    Dec 2006
    Tigard, Oregon
    The Acme 515 is the same diameter but has a half inch more pitch than your current prop. So you will have marginally less low end pull but a little more top end. I don't think you would feel the difference. If he is letting it go cheap, it might be wise to buy it to have a spare. There is not a lot of labor in swapping props, assuming you have a prop puller.
    Al
    Dec 2006
    Tigard, Oregon
    Looks like Kane beat me to the punch by a few minutes
    Al
    Pensacola, FL
    Call Acme and OJ props (eric) and see what they recommend for your boat and tell them about your buying opportunity. They will both help you out
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    May 2011
    Fort Worth
    kk, thanks guys!!! I thinkI will just get it for a spare then.
    '08 Mobius LS
    Dec 2006
    Tigard, Oregon
    Looks like your boat has a 1" shaft whereas the Acme 515 is for a 1-1/8" shaft so this would be a no go.
    Al
    May 2011
    Fort Worth
    oh, bummer. Ok
    '08 Mobius LS
