    Oct 2012
    Greenville, SC
    Default DIY Ballast Pump
    Looking for a quick option to put together a ballast pump for a couple fat sacs. Before I plumb anything in, I am going to take out a couple 400 lb ballast bags that I have laying around to test the surf wake with the bags in different locations. Just wondering if I can pickup a pump from walmart and some quick connect fittings from a depot or something. I would get it from wakemakers, but need it by tomorrow so I can head to the lake.
    Once I get them dialed in, I will plumb into my factory system, just don't want to start cutting into stuff until I know for sure.
    The problem if I remember is the Tsunami pump uses a 1 1/8" connection you can't find at HD or Lowe's. Anyone remember this? I once sanded down the bottom threads on one of these to make a lip that would take a 1" hose and a clamp.
    Later found out about this connector:
    http://www.wakemakers.com/attwood-st...00-3902-1.html
    More info here:
    http://www.wakemakers.com/wakeboard-...-aerator-pumps
    Make sure you know what you are getting and how it connects. Avoid 1 1/8" if you can.
    you will need this as well to quick connect.
    http://www.wakemakers.com/fly-high-p...ting-w734.html
    there's is one posted her in the classifieds for 75 bucks, buy it will save $$$
    May 2013
    you can heat the hose up and force it on the coupling
