Results 1 to 10 of 16
Thread: Roswell cans
    Aug 2013
    Exclamation Roswell cans
    My 06 Outback V that I picked up in July had a Kenwood speaker go out in one of the Roswell cans. When I took the speaker out I found a hand towel stuffed behind the speaker. Checked the otherside and the same thing. Is this something normal or should I pull them out of the cans? I ordered a set of Polk db651 as a replacement for the Kenwoods.
    2006 Outback V
    Wrap those Kenwoods in the towel with some heavy rocks. Wet the towel and tighten it around the contents. Then toss it overboard in the deepest part of the lake. Your system will sound much better.
    Jul 2010
    Dickinson, ND
    haha i have 6 more your can do that too!!
    07 Gravity Games Edition XLV
    -EXiled Out System Amps,Sub,Speakers,etc.. Modified Gravity III Ballast, Blue Leds Throughtout boat, still more to come!
    02 Moomba LSV "SOLD"
    Tow Rig-12' F150 Ecoboost-leveled/intake
    May 2011
    Fort Worth
    I'll toss in two!
    '08 Mobius LS
    yes, people do that to make the enclosure louder, not sure a hand towel will do the trick though, takes the tininess out.
    Arkansas
    Replace hand towel with polyfill.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    In fairness, it's probably better than nothing but polyfill would be much better.
    Mar 2008
    Vancouver WA
    Default Re: Roswell cans
    Might sound a little muddy from the bottom of the lake.
    PWI as usual...
    May 2011
    Fort Worth
    So... it will be better you are saying
    '08 Mobius LS
    Dallas, TX
    Just because you found a hand towel inside the pod doesn't mean the speaker is washed up.
