Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
  1. #21
    Mar 2013
    Orillia, Ontario< Canada
    Quote Originally Posted by loudsubz View Post
    buy a cottage, problem solved
    Ya they are giving them away up in Muskoka. LMAO
    Are they all torsion axles? So far I have replaced a few on snowmobile trailers and I don't think I am a huge fan of them. I kinda like the tried and true axle and leaf spring set up still. In my experience the cost is pretty similar by the time you buy all the parts.
    Brian
  2. #22
    Sugar Land, TX
    Default Had it with blowing tires
    Torsion axle for me. I'm betting most with issues are the torsion. Just ordered replacement brake caliper assemblies for mine too. Found both of them locking up on me yesterday.
    2011 Mobius LSV
    Ron
  3. #23
    Quote Originally Posted by rca View Post
    Got to love the brackish of the SBR!
    Sent from my iPhone
  4. #24
    Sugar Land, TX
    That's definitely part of it David, but I expected it. Tire wear is still wrong though.
    2011 Mobius LSV
    Ron
  5. #25
    Aug 2009
    Calgary,Alberta
    any of you have a tandem trailer?? how often and which way do you rotate the tires??
    2008 Moomba LSV, Gravity III, 1100 port.750 in goofy side rear,400 center,650 IBS everything else stock.....Home lake... Glennifer Lake, Alberta Canada...
  6. #26
    Feb 2013
    San Clemente, CA
    Quote Originally Posted by detipton View Post
    The original size is 225/75r14. Goodyear sold me standard load rated tires. Lessen learned now. Like I mentioned I live in Arizona and drive ~125 miles to the lake and drive about 65-70 mph and it is 105f outside. The last two tires were last weekend and the previous two were the originals from the previous owner which were old most likely last october.
    I can't find any tire in size 225/75r14? I have used Carlisle tires without any problems. Last year I learned about Kumho Trailer tires with a load D rating. With a higher load range you can increase the allowed MAX air pressure (65). With an increased air pressure it allows for higher heat and speed. I'm not sure if the tire will work for your application, but might be worth a look?
    http://www.kumhousa.com/tire/categor...E-E59335DE416C
  7. #27
    Aug 2013
    St. Paul, MN
    Inside tire wear is definitely a sign of a bent spindle or axle. These often occur when your trailer slips off the end of the cement pad while pulling your loaded trailer out. The impact doesn't have to seem that hard to bend things a little. Once your tire has most of the weight on that inside edge, they don't last long before they fail.
    Speed is another issue we are all guilty of from time to time. Add heat or uneven tire wear to that and you are having fun on the side of the road.
    I sell quite a few trailer tires on one of the other boat forums, and the same problems are all there. I sell mostly Kenda Loadstar K550 and Gladiator QR-25 trailer tires without having any warranty replacements.
  8. #28
    May 2011
    Fort Worth
    I know I am on borrowed time. I obsessively watch my tires all the way to the jam and back. My tires are 5 years old and we tow quite a bit. I reckon this thread is a sign to get replaced. Did yall jackstand and pull wheels or take the whole thing boat and all to have the tires replaced?
    '08 Mobius LS
  9. #29
    Sugar Land, TX
    I've done it both ways. If I have the boat at home I just take the tire off and take it in to my local Discount Tire. They are very quick when you just give them the wheel/tire without it on the boat. But, I've also decided to get a new tire when I wasn't at home at Discount Tire and they just jacked up the trailer and took the tire off. Very easy either way.
    I will say I have one of the Harbor Freight electric impact wrenches and that may be one of my better purchases from from. Works great on taking tires off in the driveway on all the vehicles.
    2011 Mobius LSV
    Ron
  10. #30
    I have an old Snap On impact and a compressor. I can rotate a car in about 2 min. I always just take the rims off the trailer and put the spare on one side and leave the other side blocked when I take them in. I used to mount them myself too but I'm too old for that crap now.
