Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
    Aug 2013
    SE PA
    Default Mods to my 2006 ls
    Figured I would start a mod thread for the boat..... Have them on other forums for the camper and truck....
    Added a spare tire and spare tire mount
    Next up is to drill some holes in the hull - Faria thru hull depth finder/water/air temp
    After that will be a second battery and selector
    Then led accent lighting in the boat and under water on transom
    Then tower lights
    Then amp and speakers
    Then.......
    Sent from my SGH-T999 using Tapatalk 4
    When stuck inside......
    Des Moines, IA
    Looking forward to seeing the mods you do.
    Before you drill your depth finder hole you may want to at least plan out where you will put future ballast intakes.
    Aug 2013
    SE PA
    well Samson extreme3 quick release tower mirror mount went on with the cipa Deluxe 180' mirror
    Faria SS depth water/air temp will be finished tonight - ran wires last night
    star gazer upgrade ordered .... here Thursday
    Aug 2013
    SE PA
    thru hull depth sensor/sonar is going to go in in front of the Speed paddle just starboard of centerline and keel/fins
    easily accessible through the engine compartment....
    Aug 2013
    SE PA
    Default Re: Mods to my 2006 ls
    Thru hull sensor Faria so installed tonight
    Always fun drilling new holes in your boat. My grandfather probably turns over in his grave when I drill holes in the bottom to let more water in.
    Aug 2013
    SE PA
    Perfect pass star gamer upgrade got installed tonight... Now Rollin with gps
    Aug 2013
    SE PA
    Quote Originally Posted by clarkely View Post
    Star gazer.... Damn spell check
    Aug 2013
    SE PA
    Mirror bracket and mirror added
    May 2013
    Vancouver WA
    Why put it directly in line with the paddle wheel? Isn't that going to disrupt the water flow to the paddle wheel and in turn make that reading less accurate?? Maybe you dont' care because you have stargazer?
