Results 1 to 10 of 11
Thread: Speedo Inop
    Default Speedo Inop
    So this weekend at the Texas jam my speedometer was stuck at 50+ mph. Never even wiggled....where do I start???
    Sent from my iPhone
    Feb 2008
    Traverse City, MI
    Default Speedo Inop
    Twist the knob under the dash?
    2013 Outback V
    Default Speedo Inop
    Tried that, nothing. The knob under my dash has never really done anything
    Sent from my iPhone
    Aug 2013
    DFW
    Default Speedo Inop
    Is the paddlewheel stuck with junk from the cut? Is it just the analog one or is the PP stuck also?
    Matt
    2016 Mojo
    2012 LSV (sold)
    Don't give it so much gas.
    Dun dun-dun dun....
    Default Speedo Inop
    Psh pp!!! Hahahaha. I ain't big time like that! I use Moomba cruise! It's just the analog speed gauge
    Sent from my iPhone
    Apr 2011
    Rosharon, Texas
    David I know when I had my Outback I had an issue with my speedo too. There is actually an electrical connection to it as well even though the gauges are analog.
    You can fiddle with the paddle wheel but my thoughts are the electrical harness might have a broken wire or wires?
    Rinkers would have to the know how???
    Good luck!
    PS - Moving down that way on SUnday. Maybe one day we will get to meet and you can show me where we can play on the local waters? Will be fun once in a while to get the boat out and off the ski lake!
    2014 Centurion Carbon Pro
    2004 Outback DD - SOLD
    1995 Supra TSM6 Comp - SOLD
    Stay STACKED & Pull HARD!!!
    Default Speedo Inop
    You are headed to like the south side of Houston right??
    Sent from my iPhone
    Apr 2011
    Red Mountain
    Do you tow it at freeway speeds without removing or protecting the paddle wheel? I forgot about this issue (apparently they don't like to go over 55 mph) and cooked mine last year. I found the exact replacement on ebay for a reasonable price and replaced it myself. Slightly challenging in that I wanted to use the original connectors without adding additional splices to the wiring. I did it, but it took some work with an appropriate soldering tool.
    07 Outback V
    Replicants are like any other machine - they're either a benefit or a hazard. If they're a benefit, it's not my problem.
    Default Speedo Inop
    I've never heard of anyone needing to remove or "protect" the paddle wheel to tow their boat, that is just ridiculous IMO
    Sent from my iPhone
