Results 1 to 10 of 13
    Default Cavitation or vibration issues?
    I am at my wits end so I'm looking to other experts for advice here. I have a 2000 Mooba Kamberra that has some pretty bad cavaitaion or vibration issues.. The problem is when under heavy load, such as towing a towable, the boat cavitates hard when truning right. I originaly tought the issue was cavitation so I had my prop refinished to no avail. The more load on the boat the worse the vibration is and the lake conditions don't seem to play into, it does it in calm water as well as rough water. Any suggestions or thoughts?
    Check your alignment first. Possible your shaft is just slightly out of round too.
    how difficult is it to pull the shaft?
    Oxford, MI
    Check your rudder too for looseness. Sounds like something is loose or out of tolerance, like kane mentioned the shaft may be bent and you don't know it.
    I know it sounds silly and simple and probably isn't your issue, but my boat has terrible vibrations when weeds get stuck around the prop, so I have to swim under and pull it all off.
    Nov 2009
    How hard of a turn to the right? How fast?
    -Mark
    "Hey you only live once"
    It does not matter the degree of the turn... I can backout of the turn slowly and the vibration lessens. I am leaning more towards a prop issue, if i apply trottle in the turn the vibratin gets worse. Also it does at relativly low speeds and faster speeds. We only experience this when pulling a towable tube.
    Aug 2012
    The Kamberra was v-drive right? Here is my top ten list for vibration troubleshooting. Start with #6. As old as your boat is, and the fact it worsens in turns makes this sound likely..
    1. Bent or bad Prop (Maybe the prop wasn't repaired properly)
    2. Bad Cutlass Bearing (Grab prop and see if you can move the shaft within the bearing)
    3. Bent Shaft (Can't check this by eye)
    4. Shaft out of alignment.
    5. Bent Strut
    6. Shaft coupling bolts loose (very likely).
    7. Loose engine mounts.
    8. Bad structure under engine mounts.
    9. Failed thrust bearing (probably integral to v-drive)
    10. Air in v-drive. (I have never seen this on a Moomba, but I know of it happening)
    Nate
    2008 XLV GG (sold)
    2013 LSV
    Thanks for the list Nate, I'll dive into in the next day or so and see what I can find. I talked to the guys at ACME a few minutes ago an dthey mentioned the cup may be the issue... I'm wanting to change out to an ACME 1235 anyways but hate to do that and still have the vibration issues..
    Definitely check the coupling bolts. They do come loose and are easy to tighten if you have long arms. Also, swap props with a buddy and see how you run and how he runs with yours. If his runs smoothly the prop is OK. Likewise, if you are back to smooth, it's the prop.
    Worked through the list Nate gave me as best I could, "coupling bolts" can y'all give me an idea what these are and where they are located please? I did find 3 of the 6 motor mounts slightly looser than the others but not loose enough in my opinion to be the problem. I also went ahead and ordered an ACME 1433 from Nettles, I need an extra prop regardless.
Tags for this Thread
