    Mar 2013
    Madison, AL
    Default Instructions on replacing moomba steering cable
    The teleflex SSC15418 is the correct model number cable for my 2005 moomba lsv. As far as the install: Yes, A guy on the forum I talked with sent me this and figured I would share. I have been begging on the forum for someone to put it up as a sticky. Here is a link to the PDF with instructions.
    https://docs.google.com/file/d/0B4Ku...29Ga0ozLXVIdGc
    On the LSV's the entire floor comes up with the drivers seat still attached. There is 10 screws in the floor and 3 on each side under the seats that angle into the floor(DON"T FORGET THESE!!) The floor should come up easily, don't force it. You might have to remove the U shaped carpet piece above your V-Drive, but its easy. Make sure you turn your wheel all the way left before disconnecting the old cable from the rudder and tie a rope on the end before you pull the old one through. This makes it easy to tie to the new cable and pull it back through. There is like 3-4feet under the steering wheel that the cable runs you can't see or get to so the rope trick helps a lot! Also on your new cable grease it really good before you install it to the rudder. You can push it in and out several times regreasing with a marine grade grease. It will help the long term life of the new cable. Let me know if you have any questions or run into any issues. Hope this helps!
    Reference Pics:
    https://forum.moomba.com/album.php?albumid=135
    2005 Moomba Mobius LSV
    ACME 1433 prop (newest upgrade)
    1900lbs Surf side
    This should be very helpful. Nice and thorough with lots of pics.
    Ha - I thought that hairy arm looked familiar. (SHUT IT you wise crackers!)
    Here's a direct link/cleaner version of that Google Doc if you don't want to go looking - link will not move since the website is mine.
    http://www.waketrader.net/pdf/Boat-S...eplacement.pdf
    This was from my 2001 - so the floor layout will definitely be different on others but the basic cable routing and hookups should be the same.
    Mar 2013
    Madison, AL
    Yes, great write up! I'm so glad it finally became a sticky! Very helpful a d informative. I also spoke with JesseC and he went through everything with me also.
    1900lbs Surf side
    Jun 2013
    CT
    I just did mine yesterday and these instructions were very helpful.. To add some notes:
    I have a 2005 Outback LSV, and removing the floor was easy, it comes up with a bunch of screws you can see in the floor, and 4 into the side of the floor located in the storage wells under both of the rear side seat cushions. I also removed the carpet behind the rear seat (2 screws). On my boat the captains chair comes out with the floor. If you have a subwoofer mounted in the floor panel in the drivers footwell, remove it as well and it makes the job very easy.
    Quote Originally Posted by Jayrodau View Post
