Results 1 to 3 of 3
Thread: impeller help.
02-05-2006, 06:36 PM #1Junior Member
- Feb 2006
- 2
impeller help.
Hi
Im new to moomba, and inboards. i just bought my family a new 2006 outback lsv. Now i heard something new. i just read that an impeller is better to have than a prop on inboard boats. i thought impellers were only for jet boats. anyway i should buy a second prop for my boat anyway so is this better, what does an impeller do, and how do i install it?
Thanks, Greg
02-05-2006, 07:32 PM #2
Replying to Topic 'impeller help.'
An impeller is what brings water to your engine from your raw water intake scoop on the bottom of your boat. It is made of rubber. You check/replace these usually after every year when you get it winterized. They are only around $35. I suggest definitely keeping a spare in your boat. Your impeller housing is on the front of your engine (very back of the boat since your boat is a v-drive and the engine is turned around backwards). You will see two two hoses attached to the housing. One is the hose from your raw water scoop and the other takes the water from the housing to your engine for cooling. Basically, you take out four screws and remove a plate on your impeller housing. You can use a pair of pliers or an impeller puller to remove it. You just slide the new impeller in after you get the old one out and screw the plate back on. Job done.
02-06-2006, 12:54 PM #3Member
- Jul 2005
- Birmingham
- 69
Here is a thread I started after replacing mine.
This thread is getting alot of mileage! :P
water pump impeller findings
Impeller Help
By Richard Peabody in forum Service & RepairReplies: 9Last Post: 06-12-2023, 09:48 AM -
Impeller replacement
By moomba_armada in forum Service & RepairReplies: 2Last Post: 12-07-2007, 12:43 PM -
Impeller Removal
By BigRed0803 in forum Service & RepairReplies: 15Last Post: 09-05-2006, 09:41 AM -
What Impeller?
By pls4912 in forum Service & RepairReplies: 2Last Post: 06-15-2006, 01:51 PM -
Impeller????????????
By SoTX in forum Service & RepairReplies: 5Last Post: 06-09-2006, 11:52 PM
