Results 11 to 20 of 23
  1. #11
    Aug 2013
    Wellford, SC
    Every time i post the picture links it doesn't post my reply??
  2. #12
    Aug 2012
    Morganton, NC
    Quote Originally Posted by Stroble View Post
    I have better success uploading from Tapatalk but through the forum, you have to put the picture on a hosting site such as Photobucket. Then come back the the forum and click insert image then 'from URL', use the IMG line from Photobucket.
    When I try uploading one using the 'from computer' option, I get error #2038 after the upload bar finishes.
    2008 OBV
    325 EFI with closed cooling
    Gravity III with 750's in the rear, 400 stock floor, 750 IBS
    Servo valve ballast upgrade
    Wetsounds Rev10
    JL Amps, WS420BT
    2000 Outback LS <-- Sold!!!
    310 Carb Direct Drive
    800# Rear Locker
    750# IBS (should have kept this for the OBV)
    Dual Batteries with 2 Bank Charger System
    Kenwood Head with Remotes
    Too many hours restoring exterior from prior negligence to count!
  3. #13
    Aug 2013
    Wellford, SC
    Aug 2013
    Wellford, SC
  5. #15
    Aug 2013
    Wellford, SC
  6. #16
    Aug 2013
    Wellford, SC
    It keeps saying this everything I use any links in the reply.
    "Thank you for posting! Your post will not be visible until a moderator has approved it for posting."
  7. #17
    Aug 2012
    Morganton, NC
    That's strange, especially since your initial post had images in it. Hey Berg, any help on this?!?
    2008 OBV
    Wetsounds Rev10
    JL Amps, WS420BT
    800# Rear Locker
  8. #18
    OK, can you see them all now? (I think after you get to 10 posts you will not need moderator approval for links or pics.)
    Aug 2012
    Morganton, NC
    There they are! All 20 of them, ha! Thanks Kane.
    Of course wire colors are different through the years, but looks like both are using the blue wire to the oil sender and the non striped wire to the water sender. I'll look at my book when I get home tonight to see if it goes up to '05 and report back.
    2008 OBV
    Wetsounds Rev10
    JL Amps, WS420BT
    800# Rear Locker
  10. #20
    Quote Originally Posted by aerolland View Post
    Because we (moderators) can see the pictures immediately we don't always notice that the thread is marked as a "moderated thread"-- the type in the corner is pretty small. We approve all of these as long as there's nothing shady in the links.
