Results 1 to 10 of 13
    Jul 2013
    Default ballast bags won't completely empty
    Is it normal for ballast bags to not completely empty on their own without lifting the bags to drain them?
    Default Re: ballast bags won't completely empty
    Quote Originally Posted by mikeaddy View Post
    I seem to have to do this, and sometimes even when I lift the bag they wont drain anymore, so I click the fill switch for a few seconds (enough to have them start to fill), then hit the drains again. Now I store my bags hanging out of the lockers since I have to hang them like that to drain them completely. Storing this way lets the carpet dry under them.
    Sent from my Slider SL101 using Tapatalk HD
    Aug 2009
    If you drain them while cruising most of the water should drain out
    Jul 2013
    Is it just the forward momentum of the boat and the gravity moving the water to the back?
    Jul 2013
    Seems like such a hassel, I hope this isn't standard procedures, certainly worth the efforts when storing but not for swapping sides for surfing!
    Mike,
    What style of pumps does your system have and how much water is left in the sacs? Are there check-valves in the vent lines?
    Jul 2013
    Mike,
    Pumps ars original factory in the 2008 moomba mobius lsv (but I don't know what style they are), they're left with about 1/4 full. No check valves in the lines.
    A forth of the water remaining in the sac is pretty significant.
    Mar 2012
    South Carolina
    I have this problem with my '08 Supra 21V. Front bag drains fine but my two rear bags always have water in them, and a significant amount. Annoys me. Sometimes I will try emptying them while I have the bow up in the air at minimal speed to send all of the water to the drain hose but it doesn't always work.
    I always wondered if I replaced the factory pumps would it solve my problem. I am not sure if my drain hoses have check valves, I don't think they do.
    Just last night I drove home with probably 50% left in my rear bags. Even standing on them wouldn't work. Good thing I only live 3.5 miles to the ramp now...
    Wakemakers will suggest you move your drain pumps as close to the bag as possible. If you set up the rear bags like the ski locker I'm guessing this will fix your issue. But there is also a reason the factory switched to the reversible pumps in newer boats...
