Thread: Prop change
    Aug 2005
    Default Prop change
    I heard if you change your prop say from 13.5 x 17.5 to 13.5 x 15 the higher RPM's will save gas and get the boat out of the hole. (not for top speed) it will save on gas. Anyone try this? and is it a do it yourself job.
    Jan 2005
    Default Replying to Topic 'Prop change'
    Their was some good discussion about this not to long ago.
    http://www.moomba.com/bb/viewtopic.php?t=2299
    Like I said in that post, I have a 13 pitch by 15.5. Moomba calls it the upgraded wakeboard/altitude prop. Then I tried the standard 13.7 pitch by 17.5. You will love the hole shot with the wakeboard prop. The difference is amazing. The fuel you save will be worth it. I think my top speed with the wakeboard prop is about 37mph. So you will loose some top end speed. Just make sure you watch your RPM's and don't rev it to high. You can do it yourself if you have a prop puller.
    Hope that Helped
    Feb 2003
    Maryville, TN
    The lower pitched prop will definitely get you out of the hole faster. I think in the long run it does save on gas. I change props all of the time. Sometimes you will find one that is on the shaft pretty good. Go to your local dealer and ask to borrow their prop puller. I'm sure they'd have no problem with it. Unscrew the nut and take out the cotter pin and pop off the old prop. Lube up the new prop and shaft with vaseline and slide the new one on. Use a wrench to tighten the nut and put the cotter pin back in. After that you're set to go.
    Aug 2005
    Thanks for the info. we use the boat for wakeboarding-I'll get the CNC wakeboard prop .
    Where did you get it? what is CNC? installation sounds real easy. thanks again.
    Jan 2005
    I got mine from Skiers Choice, I had my dealer order it. It was $475. If you find one cheaper, let me know, because I need a spare. Thanks
  1. WAKEBOARD PRO PROP VS STANDARD MOOMBA PROP
    By DMON in forum General Chat
    Last Post: 05-14-2007, 11:14 AM
  2. oil change
    By michelle in forum Service & Repair
    Last Post: 09-22-2004, 01:53 PM
  3. oil change
    By Keaton in forum Boat Owners
    Last Post: 04-05-2004, 11:00 PM
  4. Oil Change and Impeller Change
    By MartyC in forum Service & Repair
    Last Post: 03-14-2004, 10:22 PM
  5. prop change
    By in forum Boat Owners
    Last Post: 02-28-2003, 04:01 PM
