    Default Check Engine Light
    I recently purchased an 07 LSV after having an 05 LS for several years.I noticed yesterday the check engine light is o for some reason. The oil level is great as the oil was recently changed. Is there some type of oil reset? Is there any other things to check? I just want to be careful and not mess anything up. Any help would be appreciated.
    Check engine will be on with a v drive until your rpms get about 1000 or 1500 I think.
    If not you could have had a battery charge issue, which it should recycle after 3 to 4 cold restarts.
    Lake Amistad, TX
    Yea it's normal. Mine comes on as soon as I start the boat, goes away as I accelerate, then comes back on when back at idle!
    2008 LSV Blue on White
    Apr 2013
    DFW
    Quote Originally Posted by tgoody14 View Post
    Check engine or check v drive. My v drive light works this way, but not engine. Could be a difference in year models though.
    Matt
    2012 LSV
    Lake Amistad, TX
    Ohh yea, sorry I'm still waking up! I'm referring to the V-drive light I believe, the one below the throttle! My bad, getting more coffee now haha
    Thanks guys for all the help. The light is no longer on after like 6 cranks after installing the new batteries.
    Good you got it figured out, low batt voltage can do that.
