Results 1 to 5 of 5
    Question Ignition Problem
    Ran boat today and stopped to inflate a tube. Plugged my pump into the 12V by the ignition and there was a short in my pump that caused the plug to smoke, so yanked it out of the 12V, but it was too late. Went to start the boat and the boat wont crank. Could turn the ignition switch to Run, but when turn to Start it wouldn't engage the starter. Tried it a couple times and then the ignition switch failed, key now turns in a complete circle and it's stuck in the Run position (all gauges on and perfect pass beeps).
    Tried hotwiring the switch to see if it was just a switch failure and it wont engage the starter when touching a jump wire to the power or the ground.
    Tried jiggling the throttle to make sure it was in neutral, no dice there either.
    Any ideas on how to troubleshoot from here?
    Default Ignition Problem
    Quote Originally Posted by REDFIVE48 View Post
    I'd start by apologizing to your boat for the attempted cruelty of making her pull a tube,
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Feb 2010
    Canton, Ga / Lake Lanier
    This from a guy who had two single tubes he was saying how much fun it was to slung the kids around in. You guys are funny always hating on the tubers. You know you're a closet tuber!
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Default Re: Ignition Problem
    If I had no kids, I woudn't pull a tube again, but the darn kids seem to like tubing even though they know how to wakeboard.
    Sent from my Slider SL101 using Tapatalk HD
    Figured it out tonight, indirectly from this board. Saw a different thread which mentioned a breaker in the engine compartment, so went looking for it. Found it, pushed it and it clicked
    Hotwired the ignition (ignition is still broken) and the starter engaged!
    If your are interested in the location of the breaker, it is the red button (pushed from right to left) in the picture below that is to the right of the CA Emission Sticker and appearing under the coil wire
