Results 1 to 6 of 6
    Jun 2005
    Michigan City, IN
    Default Is This Bad? Fiberglass Cracking?
    I brought my boat home to clean, and i wanted to make sure the paddle wheel was in good shape cause my perfect pass hasnt quite been holding speed like it should. It looked clean of debris and spun freely, but i couldnt help but notice this:
    it starts from a little more than half way on the bottom (say from where the cooler is to like the ski pylon) and its deep enough to put my fingernail in, like a heavy keying of a car. Is this normal wear and tear, or does this need to be addressed quickly because it will get alot worse?
    Where It Starts:
    Middle:
    End: A tic tac size spot where i can see the fiberglass chipped away.
    Nov 2003
    Land O Lakes, Florida
    impact damage? get it fixed as it may be letting water into the actual fiberglass
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Jun 2005
    Michigan City, IN
    and where would i go about finding someone to fix it that wont rape me?
    Mar 2003
    s.e. washington state
    High school car shop.
    1998 Mobius
    310 HP PCM
    Pensacola, FL
    If you have a dremel, you tube and some gel coat, you could do it for about $40.
    Watch youtube for gelcoat repairs. You will need to "open" that crack slightly with a dremel tool, then fill it with gelcoat repair kit, sand and buff.
    Check you yellow pages for a fiberglass shop. They should charge @ $200 for that.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    Sep 2010
    Lake wallenpaupack PA
    Duck tape, use the camo color nobody will see it
