Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
  1. #21
    Feb 2010
    Canton, Ga / Lake Lanier
    Default Quick and cheap mod!
    Ordered! How do you get the gauges out? Is there some sort of retainer clip behind?
    There are two screw posts on the back of each gauge. There is a retaining bracket that the screw post go through and are held down with a tiny nut and washer. Unscrew the nut and washer and the "bracket" will be able to be removed then just pull out the gauge. I did it by hand but would recommend a small socket or wrench because some of those screws were pretty tight. I had a set of wire strippers for another project I was doing and had to use them to try and free up the nut. You will also need pliers to turn the plastic plug to get the bulb out.
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
  2. #22
    May 2011
    Fort Worth
    Very cool... thank you!
    '08 Mobius LS
  3. #23
    would an 06 LSV use the same lights?
    2006 Moomba Mobius LSV
    Stereo: Kenwood KMR-D562BT
    Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
    Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
  4. #24
    Feb 2010
    Yes, the '06 LSV would use the same lights. I think it will only use one perlight instead of how the '08 and up uses two for the two big gauges.
    Tow Rig:
  5. #25
    Jul 2010
    Dickinson, ND
    yeh it should be the same as my 07 xlv, just one bulb per gauge
    07 Gravity Games Edition XLV
    -EXiled Out System Amps,Sub,Speakers,etc.. Modified Gravity III Ballast, Blue Leds Throughtout boat, still more to come!
    02 Moomba LSV "SOLD"
    Tow Rig-12' F150 Ecoboost-leveled/intake
  6. #26
    Quote Originally Posted by powerstroke99 View Post
    To replace them just takes a lil body flexing and going underneath dash to twist out lil black tab remove bulb, insert new led and good to go.. if it does'nt light up just have to rotate bulb in fitting to get correct + and - .. hardest one i thought was the trim gauge for wake plate
    heres exact ones i bought, well got free using ebay bucks
    http://www.ebay.com/itm/20X-T10-194-...1f7e26&vxp=mtr
    how did the price of this go up to $60?
  7. #27
    Jun 2013
    Quote Originally Posted by spyder View Post
    Must have seen everybody from this forum scooping up all the inventory and deciding his price was too low!!
    If you only need 8 like everyone else, I could certainly part with some of mine which I will probably never use anyplace else -- send me a PM and we can probably work something out...
    Mike
    2013 Outback V
  8. #28
  9. #29
    Feb 2010
    WOW! These are most certainly NOT worth $60. I had one or 2 that didn't even work. They were priced right at $11. I have some extras too if someone wants them.
    Tow Rig:
  10. #30
    Feb 2013
    Norcross, GA & Lake Lanier
    Default Re: Quick and cheap mod!
    You can easily find 10 for $10.. they come in 3 different quality NOT sure what they are selling....
