Results 1 to 7 of 7
    Mar 2013
    Madison, AL
    Default Perfect Pass cable
    My perfect pass servo motor needs replacing, but I also want to replace the cable attached to it. I'm guess this is the throttle cable? How hard is it to replace the cable? Want to ask before I ordered everything. Thanks.
    2005 Moomba Mobius LSV
    ACME 1433 prop (newest upgrade)
    1900lbs Surf side
    Jan 2003
    Minnesota and Wisconsin
    Well if you are replacing the servo and the cable - I would think it would be as a single unit. Basically PP without the gauge? Or do you plan to keep the original wiring harness? I have never removed a cable from the servo - but the linkage at the carb/throttle is no big deal - a little finicky - but not difficult.
    You talking the little cable that attaches to the PP servo or the entire throttle cable from up at the helm back?
    Aug 2011
    Quote Originally Posted by Jayrodau View Post
    Why are you replacing the servo? You can service it, just need to remove the 4 screws and clean all the rust out....
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Mar 2013
    Madison, AL
    Cable that attaches to the PP servo. Have you done this before?
    1900lbs Surf side
    Mar 2013
    Madison, AL
    Quote Originally Posted by parrothd View Post
    I wish it was that simple.
    1900lbs Surf side
    That's why I was asking. When I ordered mine they sent me 2 cables to try out, one longer than the other. Swapping them was quite easy. I probably still have the instructions if needed. In fact, I believe I may still have the cable I didn't use floating around somewhere. I asked PP if they wanted me to ship it back and they said to just keep it.
    If I get the chance I'll measure it tonight. If it will fit - you can have it.
