Results 1 to 10 of 10
    Feb 2010
    Canton, Ga / Lake Lanier
    Default Ballast timer issues
    The last few times we've been out I've had some problems with the ballast timers. I have the rears set to 11 mins and the front set to 930. The front pump fills both the center and the IBS.
    The problem that I am having is I can fill up all the bags that I need to fine and the levels will reach whatever they need to be whether it be 100% 75% or whatever. We'll surf or whatever and then when I look at the fill levels they'll be registering much less than they were previously and no water has been drained and the pumps haven't been on. Yesterday for example the left pump was 92% the front was about 66% and the right was 36%. Went to drain them and the right pump drained fine but half way through the front and left stopped and registered 0% when there was easily 50-75% still left in the bags. I had to drain them (1100 and 400#s) in 30 sec increments. Has anyone ever had this problem before or know of a resolution?
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    sounds like something is off with the control module. you didn't get it wet, did you?
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Feb 2010
    You're kidding right? It's a boat...
    Nothing has gotten wet that wouldn't normally get wet while using a boat...outside...in water
    Tow Rig:
    Yes, I'm kidding. I've asked SC to respond to this one.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Feb 2003
    Maryville, TN
    E4Nash,
    I forgot to say something about this when we were talking yesterday. Try doing a hard reset on your ballast PDM. Disconnect both the power and ground from the PDM and let it sit for about 10 minutes, then reconnect. Hopefully this fixes your issues. If not, send me an email.
    Feb 2010
    Thanks Jon will do...now where is the PDM for the ballast located in my boat?
    Tow Rig:
    Feb 2003
    Maryville, TN
    Port side rear locker. Pumps and Pdm are mounted on a board behind the carpeted panel towards the transom.
    Feb 2010
    Quote Originally Posted by Jon View Post
    So that's what the black box above the pumps is...gotcha thanks!
    Tow Rig:
    Jul 2013
    Whiteshell, MB
    Is the hard reset working for you guys?
    I get the pumps cutting out on both fill and drain. I also have the pumps not filling OR draining in accordance with the % on the screen (when they don't cut out). I went to fill the center tank once and at 10% it was coming out the vent.... once, while on the lift and gauge at 0%, I hit drain and listened to water spill out for a few minutes..
    If the hard reset is working i will give it a try,but where is it on the 2012 Mojo? (Why wouldn't it reset each time i switch my batteries to the off position?)
    Thanks,
    2012 Mojo2.5
    Ballast:
    1100 surf side
    400 goofy side
    500 under floor
    725 IBS
    260 bow floor
    (The more spotters the better)
    Acme1235
    Feb 2010
    I haven't been able to do the reset yet...was going to do it this past Saturday but work got in the way. Hopefully I'll get to it this week sometime.
    Tow Rig:
