Results 1 to 4 of 4
    Apr 2004
    Jax, FL
    Question Wiring for high press fuel pump 2000 Moomba Mobius V
    Having trouble installing the new retrofit hp fuel pump. Does anyone have a correct wiring diagram?
    Going to be a tough one to find on a boat this old...
    Aug 2012
    Morganton, NC
    Default Re: Wiring for high press fuel pump 2000 Moomba Mobius V
    I've got a couple more of those don't help. Need to know what type of ignition you've got to narrow it down. Leaving tomorrow around 2 for a little boat vacation myself, book is staying at the house for good luck...
    Hope it helps.
    Sent from my S3 using Tapatalk 2
    2008 OBV
    325 EFI with closed cooling
    Gravity III with 750's in the rear, 400 stock floor, 750 IBS
    Servo valve ballast upgrade
    Wetsounds Rev10
    JL Amps, WS420BT
    2000 Outback LS <-- Sold!!!
    310 Carb Direct Drive
    800# Rear Locker
    Kenwood Head with Remotes
    Great stuff! Where did you get this?
