Results 1 to 2 of 2
    Crosby TX
    Default Center ballast empty pump not working.
    I have a 2010 obv with only the center ballast. The problem is it will not empty. The empty pump works when I plug it into the fill plug. When I put my meter on the empty plug and turn it on it shows 12 volts. If I plug the pump in it shows 0 volts when it's turned on. Any help would be greatly appreciated.
    Thanks Rodney
    Crosby TX
    Never mind found it!! The wiring going into the five amp fuse holder was not making a good connection.
