Results 1 to 10 of 12
    Jul 2009
    Marquette, Michigan
    Default One slow ballast pump
    My center tank and Starboard rear bag fill fast and consistent, but I had to bump up the timer an additional 3 minutes to get the port side to fill all the way. I checked the impeller and it looks perfect.
    Anyone have a similar experience, or have any ideas why this would be? I know the speed on the pumps will vary a little, but this seems like quite a difference....
    2016 Moomba Mojo
    are you filling with the boat running?
    Jul 2009
    Marquette, Michigan
    Yup. I always fill and empty with the boat running.
    2016 Moomba Mojo
    you don't have a bigger bag in the port side, do you?
    let's assume not. It would be a pain the arse, but you could swap out the fill line with another pump to see if the pump is the issue or if it's something else. check to make sure the valves on the thru hull intakes are all wide open, look for kinks in the hose, etc.
    Mar 2008
    Vancouver WA
    Default Re: One slow ballast pump
    My guess is a kinked line.
    PWI as usual...
    Jul 2009
    Marquette, Michigan
    I'm getting that pump replaced under warranty. Hopefully that fixes it.
    2016 Moomba Mojo
    Jun 2014
    Quote Originally Posted by yooper View Post
    Did you find a solution? I have a mobius lsv 2013. Same exact problem.
    Jun 2014
    May 2014
    Clermont, Fl
    ever count the number of flashes on the switch?
    It is real easy to get the timer out of whack.
    Jul 2011
    Murrieta, CA
    A worn ballast pump impeller can slow the drain/fill times.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
