Results 1 to 10 of 15
    Default Bad ground? Speakers Popping
    Title says most of it. My speakers are popping but only when I use the trim switch. any suggestions? I follow instructions well and like visual help, LOL I have wired before, and fixed electrical issues on other things, but I have a new to me '06 Outback V and I didn't test those two items at the same time in the test drive!
    Also if you have any suggestions as to why the hour meter reads error 1 that would be awesome. I did have it =certified at the dealer as having 155.4 hours
    Jun 2010
    Lake Houston
    Default Re: Bad ground? Speakers Popping
    Most def a ground issue. Make sure the head unit and amps are grounded alllllllll the way back to the source battery. No grounding strips either, dedicated wires to all devices.
    2013 LSV
    2005 LSV - SOLD
    AMPS check, I will check head unit when I get home tonight....dang work gets in the way of important stuff!
    Your pop is most likely caused by the wake plate motor itself. Its a relatively simple fix that involves wiring in a couple of CAPs across the switch. Try doing a search here as I think Phil with Kicker has posted on this subject a few times and has specs on the CAP's and a wiring diagram
    The trim function on an I/O and the wake plate function on a towboat are known to create a wicked transient through the audio system. The pump motor of either pull a lot of current. The pump motors are triggered by either a relay controlled by a switch or directly by a switch. And it is the arc across the switch or relay contacts that cause the voltage spike. To fix this you place a capacitor on both the 'up' and 'down' triggers. In some really bad instances the parts/circuit need to be more complex. And in some cases the contacts are worn enough that you have to replace the switch.
    A ground loop can make your audio system more vulnerable to this noise. But if it were just a ground loop you would probably be picking up other noises as well such as the blower motor or alternator.
    Odin with Earmark has the parts to fix any noise scenario including this one which come with very complete instructions.
    I stopped by Radio Shack and picked up a couple of caps to give it a go this evening. Tanks for all the input
    '06 Outback V
    325 Assault MPI
    4 wires coming out of trim red goes to 25 amp fuse and then to buss bar. The other 3 to back of boat hydraulics Where do I run capacitor
    Sent via smoke signal using my Zach Morris brick phone.
    '06 Outback V
    325 Assault MPI
    Here is a link to a previous post made by Phil where he has provided instructions and a diagram. The easiest place to wire those in will be under the helm where the wires leave the switch.
    http://www.wakeworld.com/forum/showthread.php?t=745329
    Awesome just got it done. 95% of pop is gone. Wonder if a larger cap would do better. I am pleased with result but still a little crackle now
    '06 Outback V
    325 Assault MPI
    Nov 2009
    Stillwater, Oklahoma
    Glad to see you got a source for the image Jughead! Sorry about not getting your PM until this morning.
    An item often overlooked, yet really a major contributor to trim pops is the fact that we are energizing a magnetic coil in the valve solenoids. When we hit a switch we pour 12 volts into the coil creating the magnetic portion of a linear motor, causing a hunk of magnetized steel to move, opening a valve. When we release the switch, we turn off the voltage, the magnetic field collapses.... the steel actuator returns to rest, moving through the coil.... Ther are three events total, one being the switch being hit. Then two separate events when you release the switch, although simultaneous... Both potentially making noise.
    On the topic of magnetic fields collapsing in coils, how many of you know how a magneto works on a PWC, lawnmower or motorcycle? Flying a magnet by a coil we induce a current and a voltage in the coil called the primary coil. Then the points open, (same as releasing a switch) creating a similar collapsing magnetic field. The collapsing magnetism in the primary coil induces a current and a very high voltage in the secondary coil, which is connected directly to the spark plug! Bottom-line a coil will create a lot of energy when you REMOVE power from it, just like the switch can create a spark which makes its own noise. This in part explains why sometimes you hear pops both when you press the trim switch AND release it.
    The second thing to consider when you release the trim switch is the part of the solenoid that moves inside the coil that opens the valve. When you release power, that magnetized metal MOVES from the valve-open position to the valve-closed position. When you move a magnet past a coil what do you get????? ding ding ding.... voltage and current...
    So considering this and thinking it through there are actually several contributors all aligned against you in any solenoid controlled device... both when you push the switch AND when you release it.
    I am of the opinion that the capacitor installation benefits a trim circuit in two ways. First, when hitting the trim switch to energize the solenoid, the capacitor slows the transition from zero volts to 12 volts in the solenoid coil as a function of charging the capacitor. If viewed upon an oscilloscope the capacitor "rounds over" the sharp transition from zero volts to 12 volts.
    Then when the switch is released the capacitor absorbs the transient created by the collapsing magnetic field, shunting it slowly to ground, (slowly is a very relative term here...).
    I try to keep my explanations relatively simple, but this one went a little further than usual. Hopfully it makes sense?
    Phil
    Kicker
