Thread: Speedometers
    Mar 2013
    Orillia, Ontario< Canada
    Default Speedometers
    I need to put a new speedo in my Boomerang, I think.... Both pickups are broken off and I haven't had any luck in finding replacements for them. What would be the best route to go, GPS, or?????? Can I buy the parts for these old Air Guide speedos? I assume the only reason there is 2 speedos is to ensure accuracy. Thanks for your input.
    Brian
    Mar 2003
    s.e. washington state
    Discount Inboard Marine has replacement pitots with a different mounting hole placement. Anything else on the Airguide and you're sol.
    1998 Mobius
    310 HP PCM
    Pensacola, FL
    Your boat has 2 speedos because AWSA requirements used to be that you needed 2 for accuracy.
    When you order, you may want to get at least one new ballast also. It is the part inside the boat that changes water pressure into the gauge reading.
    skidim.com may be source.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    Nashville, TN
    2nd skidim.com I bought 2 from them end of last season.
    1998 Outback
