Results 1 to 10 of 14
    Nov 2008
    Default Hot water on footwell carpet
    Cruised accross the lake for dinner last night, and pulling back in, noticed that there was water around the edges of the driver's footwell. It was pretty warm. Took a look around, and the ski locker was filled almost halfway up, so i'm guessing it was sloshing through my speaker wire holes in the locker. I regularly have water in the ski locker and bilge, but not this much in one trip.
    I won't be able to hit the water for another week or so, so hoping to get some ideas of where to look. I have a test plug in my ski locker, so that is usually pretty good about stopping bilge water, but the fact that it's warm makes me think it has to be coming from the bilge, and not under the ski locker where I've installed a deck plate.
    I just replaced my prop, and had to take it to a shop to get the old prop off because it was totally stuck... took some force, so my first guess is maybe my prop shaft seal, but that sure seems like a lot of water for one trip accross the lake. My other thought was an exhaust leak, which would explain the temp of the water, but I looked around and couldn't see anything wrong there.
    Any other thoughts?
    '13 Mobius LSV
    '05 Mobius LSV - Sold
    Do you have a heater? The heater core is normally on the other side of that foot well and has hot water from the engine running to it.
    Nov 2008
    I do. Never used it, but I know it has one. Is there an easy way to get to or inspect the core?
    '13 Mobius LSV
    Jun 2009
    South West Colorado
    Go in under the stbd side bow seat. It's tight but you can get at the heater core and hoses. Could be a frozen/ busted core, if it was not winterized properly.
    '08 Mobius LSV- SOLD!
    2017 Mojo Pro
    Mar 2003
    s.e. washington state
    You are an owner of a failed heater core. They also fail over time like mine did. You can get replacement cores.
    1998 Mobius
    310 HP PCM
    Nov 2008
    It definitely didn't freeze. Not even sure we've had freezing temps in the last year. Definitely sound like it has failed though. Can I bypass it if I never care to use it? Maybe install a shutoff valve?
    '13 Mobius LSV
    Mar 2003
    I would recommend by passing it by capping it at the engine
    1998 Mobius
    310 HP PCM
    Quote Originally Posted by csm View Post
    You can by pass it, by the above way or just get a double male connector and hook the two hoses together at the heater core.
    Nov 2008
    Cool thanks guys.
    '13 Mobius LSV
    Should be two shutoffs in the engine compartment to close the loop.
