Page 29 of 31 FirstFirst ... 192728293031 LastLast
Results 281 to 290 of 305
  1. #281
    Eugene OR
    Yes, you did and I agree with your sentiment that they are both great boats. Just didn't want folks to think that they simply threw a different front end on the SA.
    no worries.
    All I got it. I agree. I should have stated it better.
  2. #282
    Some of the differences if you want to get more technical about the SC and the SA
    SC is a couple inches wider in the main cabin due to the 102 beam
    The SC is also 4 inches Deeper in the seating thought the entire boat
    The SC is 10 inches shorter then the SA but thats due to the Bow and the Sun Pan on the SC is very small.
    The SC still retain the 200 hard tank in the rear and the 500 in the floor
    The SC has Plug and Play for the rear Lockers, and the IBS so you can plug bags in and the main pumps in the boat will fill and drain with no other changes
    The SC also has the same tower as the SA BUT it has interior panels on the inside and you can color match the outside panel to blenb better with your boat colors.
    The new SC front hull is designed to keep the nose low in the water when surfing, and it had ridges that are specific to surfing so when you slow down the water is pushed away from the nose to reduce incoming rollers.
    There is also on the rear of the boat, looking at the current Black and White SC where the Black is on the rear 1/4 is a 1/2 inch lip and this is used to help shape the surf wave.
  3. #283
    Jul 2012
    Pearland Texas
    Thanks for the write up man.
    Chris H.
    2012 Mojo
    Wake Life
  4. #284
    Quote Originally Posted by C.Hern5972 View Post
    I got a full review with pics im doing like i did the SC last year and the Mojo, just no time yet, very busy with work and Wake the World this weekend.
  5. #285
    Eugene OR
    Mike there was no SC last year. You mean the SA.
  6. #286
    Quote Originally Posted by jester View Post
    Oh, now you want to be precise?!?!?
  7. #287
    Eugene OR
    YUP .
    Dang it i needed 10 letters to post.
  8. #288
    Aug 2012
    [QUOTE=wolfeman131;222674]stock ballast
    I believe capacity is a NMMA formula based on gross weight of vessel, less factory ballast divided by some arbitrary avg weight per person. Has nothing to do with # of seats, configuration, etc.
    My LSV has 1800#s of stock ballast, and an 1800# capacity. Does this mean I can't get in the boat when the ballast is full?
    Nate
    2008 XLV GG (sold)
    2013 LSV
  9. #289
    correct. you are to fill the boat and then sit on the dock while I take your boat out for a proper surf session.
  10. #290
    Jul 2010
    Tennessee
