    Tewkesbury, ENGLAND, U.K.
    Default Perfect Pass display interchangeability
    I have a PP Wakeboard Pro mechanical system, but the screen keeps fading, although the system still works.
    My friend has given me a display from a DBW system, so the connector is different althought the displays are the same.
    I want to test my system with his display.
    Is this possible? Is there a connector adaptor available between the two?
    Or do i have to cut the wires and reconnect the new display to the old module harness?
    Dave Longbotham
    Minsterworth Waterski Club
    River Severn
    England
    U.K.
    Mobius V 2000
    d.longbotham@virgin.net
    www.youtube.com/user/Wolfstone1000
    Mar 2008
    Vancouver WA
    Default Re: Perfect Pass display interchangeability
    Call perfect pass and ask them. Really good guys to deal with and super helpful.
    PWI as usual...
    Perfect Pass contacted but they do not have an adaptor available.
    I read a few posts about these gauges, apparently moisture may be to blame.
    So, at the weekend, I took a hairdryer and blew hot air into the back of the gauge, then stuffed loads of silca gel in there, and taped the back up so no air could get in.
    Fingers crossed, its been fine since....
    Dave Longbotham
    River Severn
    England
    U.K.
    Mobius V 2000
    Jul 2012
    I was told that at low voltage, the system will still work, but the screen will not fully illuminate. I had this problem once and at the end of the day, my battery had recharged, the screen was fine. New battery and it's worked well since.
    DDNorCal
    2006 LSV
    3430 Ballast, 1847 Prop, all around great boat
