Results 1 to 8 of 8
    Oct 2010
    Winnipeg, Manitoba
    Default Prop shaft packing
    Yes it seems this subject has been flogged to death. I need to do mine and have never done one before. I looked on both the Moomba and Supra forums, but stumbled on this "diamond", using google. It's great pictures of what's involved and a pretty detailed explanation on how to do it. So I though I would share. I haven't run across this in any of the forums.
    http://www.pbase.com/mainecruising/stuffing_box&page=1
    Hope someone else finds it helpful too.
    Thanks to DOCDRS for his help to this point. He had a bunch of good stuff on the forums about this.
    past---------------2003 Outback SOLD
    Ron
    Aug 2007
    Alpine, Utah
    I have an 07 Mobius LS with the dripless shaft. Is the packing the same on a dripless? Do you change it the same way?
    Garn
    Garn
    2007 Mobius LS (Direct Drive)
    Oct 2010
    Winnipeg, Manitoba
    Quote Originally Posted by Garn View Post
    Garn
    I don't know. Haven't looked at drip less, as mine is the same as the link I provided.
    Ron
    Oct 2008
    Central, Arkansas
    Garn
    There is no packing to worry with with a dripless setup.
    Aug 2007
    Alpine, Utah
    If there is no packing on a dripless shft, but it is leaking, what do I fix/replace?
    Garn
    Jul 2013
    jonesboro IN
    if memory serves me. the dripless has a water cooled rubber seal.
    May 2013
    Vancouver WA
    that is a pretty amazing writeup.
    Jun 2011
    Raleigh, NC
    I used that write up, and it helped alot. The one thing I found on an 03 was that the Goretex was a bit smaller they the flax, and was alot easier to use. So.. go with the new fancy stuff and it will be alot easier.
    2003 Mobius LSV Gravity Games
    Total Noob running 1100 in the center, 750s in the lockers.
    JL JX360/4 powering 6 Infinity 621m speakers
