    Default 2012 Mojo center ballast
    Hello, I an happy new owner of a 2012 Mojo and have 2 questions:
    - is it possible to replace / upgrade the center ballast of the mojo?
    - I have the stock gravity 3 ballast system, is it correct that each ballast are 150lbs so the total is 450lbs ?
    I plan to upgrade my ballasts and do something like wolfeman131 (nice ballast setup).
    Thanks for your help
    2012 Moomba Mojo 2.5
    2x1100lbs, 370lbs, center hard tank+IBS
    ACME 1235 prop
    Wakeboard Hyperlite Belmont
    Wakeskate Hyperlite Byerly
    Wakesurf Hyperlite Broadcast 5.4
    Default Re: 2012 Mojo center ballast
    The center/bow is a hard tank, so no upgrade. Add the IBS and you will be happy. Stock rear bags are 550 or 650. Whatever they are, upgrade to the 1100's and you will be happy.
    Although, you should be happy anyway since you're riding in a Mojo. Do the above and you will be happier.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Thks for reply ! Ok so I have a 450lbs center and 2 x 450lbs at rear. I will upgrade to the 1100 and had the IBS. I reply to your post about your ballast setup and had some questions :
    Your 370lbs bag is not the 62" long ?! And if I use one of the rear (450lbs) ?
    When you fill your 1100 and your 370 (with the T connection), what happend when the 370 is full ? you have 730 lbs going back to the lake by the vent while the 1100 is filling ?
    did you keep the list of all the hose and fitting that you used for your upgrade ?
    ACME 1235 prop
    Apr 2011
    NY
    Quote Originally Posted by gurt View Post
    He and I both have this bag under the seat:http://www.wakemakers.com/fly-high-tube-sac.html
    Fits and fills perfectly.
    The 370 is vented back to the 1100. When the 370 is full the added water is pushed to the 1100 the 1100 is then vented with a check valve to the TH fitting. When both bags are full water is pushe out the vent.
    '06 Outback - Gone but not forgotten
    '13 Mojo
