Results 1 to 10 of 18
    Default 2013 LSV surf set up
    Hey I was wondering if anyone has surfed the new LSV's yet , and whats the best setup with ballasts , wake plate and speed to run ?
    use the search function & you'll find a ton on this.
    you can also check out how folks have set up their Mojos and/or 13 LSV's as they are similar:
    start with:
    1,100 in lockers (surf side full, off side 50% or less)
    370 under seats (surf side full, off side empty)
    bow tank full
    IBS full
    wakeplate 75% to 100% up
    10.0-11.2 mph
    as of right now im running. 1100 bag in port rear locker, front tank plus 650 ibs under bow seats. wakeplate in bow up-all the way, running about 10-10.5mph. have tried filling some weight in the opposite locker but it has a negative affect at this point due to my lakes shallowness. I do have more ballast bags on order that wakemakers is saying will ship out later this month to use when we go on vacation in july.
    Lemme know if you wanna go throw her in Lake Tarpon on your weekday day off in the next couple of weeks for a test run before your vacation. I need to head down your way at some point and I'd love to help you nail your setup and get some surfing in.
    sure thing, only weekdays off till vacation are june 25th and july 4th at this time, dont think i would even try to go out on the 4th unless you can be at my lake at 9am, otherwise I will be sitting poolside with a few cold ones close by.
    work does not allow for enough time of to surf.
    Sad but true.
    I have a new t-shirt you would probably like
    Feb 2010
    Canton, Ga / Lake Lanier
    I too prefer it WITHOUT any weight in the opposite side.
    I'm running:
    1100 surf side rear locker
    370 surf side under seats
    370 in floor locker
    650 in bow
    Wake plate 75-100% up
    Speed about 9.8
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Oct 2011
    Lake Wylie, SC
    Default Re: 2013 LSV surf set up
    Rode e4 wave on Friday. His set up is spot on.
    With extra 200 on surf side sun deck, 200 bow, 100+ surf side rear corner, 100+ on observer seat, 200 driving...
    Gotta love movable ballast.
    From the mobile
    Jun 2010
    Lake Houston
    I PERSONALLY think the surf setup is different for the pre-2013 models. The freeboard is much higher. The seats are higher, the captain is higher, the gunnels are higher, etc. The point im making is the center of gravity is much taller on this boat so it LISTS side to side more readily/easily. Just being around for a while and seeing how this boat responds over the different years, this boat likes corner weight and nose weight. I weighted my boat with the 1000lb "L" shaped bag on the seats plus stock ballast plus ibs and you couldnt even stay in the wave.
    2013 LSV
    2005 LSV - SOLD
    Feb 2010
    It's the same hull though...so it should move water the same way...no?
    Tow Rig:
