Results 1 to 8 of 8
Thread: fat sac's
    Irondequoit Bay, NY
    Default fat sac's
    so im going to add more weight to the boat this summer. As of right now i have a older fly high fat seat in the back that holds a little more then 1,000lbs and i plan to put the W703's under the bow seats, then i also plan on adding a tube sac in the walk way. all of this im just at about 2Klbs of weight..and yes i did upgrade my prop to a ACME 543 ( talked to nettles bout running 2k of weight and thats the prop i was told to get) what do yall think?
    W703's http://www.wakemakers.com/fly-high-side-sacs.html
    tube sac http://www.wakemakers.com/fly-high-b...-60x15x10.html
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Jul 2012
    Cumming Ga
    I think I can save you 60 bucks on a tube sack
    Irondequoit Bay, NY
    let me know
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Portland Oregon
    Default fat sac's
    I loved the 543 on my DD Centurion, at lower speeds it rode a little higher in the bow which made it perfect for handling rougher water and big wakes. I didn't lose much top end and she got out of the hole great when I would load it up.
    -Jake
    Irondequoit Bay, NY
    there was a post in the wakeboard thread(few weeks ago) on a 01? outback with two sacks in the back and everything else im looking at getting, but since i cant put anything in the sun pad area i had picked up the fat seat(last summer)..but id like to really start surfing and i know everyone says to keep the bow full so i plan on that..just wondering about how well the seat will work for this or if i should try and sell it and get two bags for the back instead
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Nov 2003
    Land O Lakes, Florida
    it this for wakeboarding or for surfing. sounds like a lot of weight for a outback
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Oct 2005
    Durham, NC
    moto,
    I replied to your PM, but i'll sum up here. I think it should work pretty good, just maybe a tad bow light/stern heavy.
    Maybe swapping the fat seat out for a 750# fat sac (W707), or maybe even the 650# rear seat/center locker sac (W705) might work a little better? If you use the latter, you could probably still use the rear cushion up in the sunpad position. This would allow for extra peeps in the back of the boat w/o throwing the weight off balance.
    It is a lot of weight for an Outback, but with careful driving, it is doable. Just make sure your bilge pump works, cuz you'll be taking water over the bow quite a bit. The bow rubrail will only be about 3" above the water level when stopped.
    I have an old PM from Ed G about how he used to set up his 2003 Outback for surfing. I will see if I can forward it to you.
    Brian Roberts
    2001 Outback DD
    Irondequoit Bay, NY
    sounds good..i got the messages as well
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
