Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Jan 2003
    Minnesota and Wisconsin
    There are a lot of elements thatresult in failure to get up. The rope is never one of them.
    Most people try to stadn up to soon. Even these big boats need some time to develop horsepower.
    Often I see people think they are not getting enough power so they ask for more power and that can be a problem.
    Many inexperienced drivers think they need to get you up to speed right away or you will be angry so they rush the throttle.
    I have found that training them to watch the tach rather than the speedometer works pretty good. Never rev the tach past where you would normally ski. Instead a steady increase in power up to about 3000 RPM is usually good. If you have speed control like Perfect Pass a steady increase to about 12-18 mph is usually enough and then the PP will kick in and finish.
    One other trick that has worked for some (especially if you start on one foot) - do not sit in the water all balled up trying to maintain that perfect starting position while the rope feeds out and the driver gets ready. Float comfortably with your feet well out in front and as the boat starts to pull allow your body to compress into the starting position. This may prevent you from trying to stand too soon and allow the boat to develope some horsepower.
    Remember - you can get out of the water in a very squatted position if you want - but you can not if you bury the tip.
    You do not need a 10 section rope. Unless you have some crazy good skiers you hang with. Having said that - I have one and love tinkering with short line - but my coach hates it when I do.
    Good luck - and avoid skiing on the tower - most boats are not really designed to handle slalom from the tower.
    Have Fun
    Dave
  2. #12
    Sep 2010
    Camp on pool 8 of Allegheny River (Adrian, PA)
    Brian - as usual the Forum has given lots of good info...I only have one additional note. Focus on putting down pressure on the ball of your foot (back leg) this will help keep the tip of the ski up early in the pull as you work to get up on the water. If you are using a double boot leave the binding a little loose to allow the heel of your back foot to lift up as you apply down pressure on the ball of your foot. This is what my two sons and I use (focus on) and as the others have noted, hold on and the rest will happen. Mike
    2003 Outback
    Boat name = Lynn Syndrome
    Its a condition that runs in the family...Judy Lynn (mother-in-law) Heather Lynn (wife) & Megan Lynn (daughter)...no known cure...but the boat helps
    New boat for me on 10/9/10.
