Results 1 to 10 of 17
    Mar 2013
    Madison, AL
    Default WTB: fat sacs or fly high
    Anyone have any used fat sacs they are looking to sell? I im wanting to add or upgrade my G3 stock rear lockers for wakesuring.
    2005 Moomba Mobius LSV
    ACME 1433 prop (newest upgrade)
    1900lbs Surf side
    Apr 2011
    NY
    What sizes are you looking for?
    '06 Outback - Gone but not forgotten
    '13 Mojo
    Mar 2013
    Madison, AL
    Like 500lbs+ anything bigger than the stock 400lbs.
    1900lbs Surf side
    Apr 2011
    NY
    Ill have 2 600's as soon as my order arrives from wake makers. They are from '13 mojo.
    '13 Mojo
    Mar 2013
    Madison, AL
    Can you send me pics of the sacs to my email? jayrodau@gmail.com
    Do they have the the dual quick disconnects one for filling and one for emptying?
    Thanks,
    Jared
    1900lbs Surf side
    Apr 2011
    NY
    I tried to snap some pics in the locker but not much luck. They look just like these: https://forum.moomba.com/showthread....t=jmvotto+sacs say fill and drain ports and hold downs just different dimensions.
    Anyone out there know what they might be?
    '13 Mojo
    Quote Originally Posted by muehlcj View Post
    The black factory Mojo rear locker bags are 650, and they have 3 ports, 1 rear bottom, 1 front bottom, 1 top vent. They are how ever 1 inch fittings and glued in, so you will need to switch fitting unless you plan to run 1 inch lines and fittings.
    If you ordered new bags from Wake Makers then make sure you know how many ports and order plugs for the ports you dont need and new fittings for the ports you do need unless you plan to remove the factory fittings from or factory bags.
    Mar 2013
    Madison, AL
    Can the glued fittings be removed somehow? Heat gun possibly help loosen it? I assume my LSV has 3/4 hoses right?
    1900lbs Surf side
    Quote Originally Posted by Jayrodau View Post
    Yes and yes Wake Makers has a video on how to remove them with a hairdryer.
    http://media.wakemakers.com/2012/02/...high-fittings/
    Yes, they can. I would assume the seller would keep the 1 " fittings and put in new bags.
    Heat gun on low for 4 to 5 minutes
    Mike you got faster fingers tn me on the iPad.... Lol
