Results 1 to 9 of 9
    Jun 2013
    Default 2000 Outback fuel or electrical issue
    2000 Outback 5.7 Carb Indmar- Last season ran up river for an hour no issues- shut off for an hour- rode back down the river and it acted like it ran out of fuel- got it to run then it wouldnt restart- no fuel-
    replaced the fuel pump- Carter electric- Replaced plugs,wires,cap, rotor while I was was there- Took it out and had same issue-- Drained tank,rebuilt carb,replaced distributor module and changed fuel pressure sensor from 3 wire to two wire-- Took it out again and did the same thing- What else could it be? Fuel line? Circuit breaker? Oh yeah only 165 hours.....Boat will idle but after it warms up starts to break down...
    Apr 2012
    Juliette, GA
    Have you verified you're getting fuel all the time? Crack the fuel line going to carb, jump the two wire oil pressure sensor and the pump will run with key in run position. I had the 3 wire sensor fail and replaced it with 2 wire from DIM and that one failed with 5 hours on it. Could possibly be the anti siphon valve on the fuel tank.
    -Eric
    1998 Outback
    Jun 2013
    Thanks for the reply- Will give that a shot today- Do you think the fuel line is collapsing under load? Maybe? yesterday I ran in the driveway- idled fine- ran for about 1/2 hour- ran the RPM up to 2K for a few then it died. I let it sit and then cranked it an hour later and it died quickly- Will get back to you later this afternoon -
    Aug 2011
    Default Re: 2000 Outback fuel or electrical issue
    Vent plugged?
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Jun 2013
    Vent on tank?
    May 2010
    San Antonio, TX
    Quote Originally Posted by jjoneskw View Post
    This sounds very similar to my problems. It started doing the same thing after I took it out of storage last year. Just like you, it just seemed like it ran out of gas. When I'd pull the line off above the gas tank, it would be bone dry from the tank all the way to the pump. A lot of times it would start up but quickly run out of gas. I replaced the one way check valve above the fuel tank and thought for sure that would be the fix. No luck. Just replaced the fuel lines, fuel filter, and pump. Idled it in the driveway just fine yesterday, but haven't had the chance to take it out yet. I'm hoping it was the pump, filter or combination of both. The pump seemed to be running loud. Now it's quiet after replacing it.
    I've double checked my vent and it seems to be fine (blowing air through the vent line to the gas cap). Not really sure how to verify the fuel cap is allowing air into the vent under vacuum. Might try a run with the cap a little loose if I'm still having issues. Not a long term solution, but might help identify if the vent is able to suck air properly.
    Looking forward to what you find out.
    2006 Outback DD
    Irondequoit Bay, NY
    mine wouldnt go above 1500 RPMs before it would bogg down and wanna die..i replaced my fuel filter and ran some "dragon fire " carb cleaner through the fuel pump. then the next day i ran mine down the canal and got here up to 4000rpm's
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Jun 2013
    Not a fuel issue-- started at rear of boat, Vent open, fuel check valve not stuck, Boat gets warm and loses spark- Replaced plugs,wires, coil, distributor module,cap and rotor- something is getting hot and then shutting down boat after running for 30 minutes- Anyone out there have an ideas? Ready to get on water but can't.....
    I know this thread is old but did y'all figure out what was going on because my outback is doing the same thing.
