    Nov 2009
    Gatineau, Quebec
    Default Help no power to fuel pump
    On the 05 outback ls for sale theres no power to the fuel pump ,when turning the key to start it will read 12.5 volts for a second then 0 even when its diconected from the pump . Is it on its own circuit ?
    2012 Mobius LSV
    05 Outback LS SOLD
    Jan 2006
    Jacksonville, FL
    Check the Oil pressure sensor. Happened on my old outback before.
    Nov 2009
    Gatineau, Quebec
    To check the oil pressure sensor do i ground the single blue wire?
    The fuel pump works if i add power to it
    2012 Mobius LSV
    05 Outback LS SOLD
    Nov 2009
    Gatineau, Quebec
    oil pressure sensor test good it goes out of limits when the ignition is turned on .
    2012 Mobius LSV
    05 Outback LS SOLD
    Jan 2006
    Jacksonville, FL
    There's a wire u can jump to see if it's tgat
