Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Lake Village, AR
    Whenever you use gas, oil diesel, etc. and get it on you start with a good dish soap that is designed to attract grease. Wash a couple times with something like the green palmolive or dawn and then use your regular soap. It does help a lot.
    LAVA soap is your best friend for this. I've worked on enough farm equipment and been covered in enough oil products to supply Exxon for a day. LAVA always gets it off and diesel smell is a thing of the past.
    07 Mobius LS--Razorback Red
  2. #12
    Nov 2009
    Mike if you are really in a bind use wd40 it will act like a starting fluid but it's not dry. I have used it in a bind once. Oh and modern day starting fluid is way too weak. Stupid government.
    Sent from my SCH-R970 using Tapatalk 4 Beta
    -Mark
    "Hey you only live once"
  3. #13
    My little brother used to use lacquer thinner in his copper colored Nova. That ole straight six would run on anything. Don't ask me why he had lacquer thinner but no gas.
    Aug 2012
    Morganton, NC
    WOW, now i stink of diesel fuel but my rig is running.
    I don't see the issue here... just think of it as a reminder of making the correct choice of tow vehicle!
    2008 OBV
    325 EFI with closed cooling
    Gravity III with 750's in the rear, 400 stock floor, 750 IBS
    Servo valve ballast upgrade
    Wetsounds Rev10
    JL Amps, WS420BT
    2000 Outback LS <-- Sold!!!
    310 Carb Direct Drive
    800# Rear Locker
    750# IBS (should have kept this for the OBV)
    Dual Batteries with 2 Bank Charger System
    Kenwood Head with Remotes
    Too many hours restoring exterior from prior negligence to count!
  5. #15
    Quote Originally Posted by aerolland View Post
    Ohh i wasnt really complaining, the Mrs did when she came home, but then again after working on the truck all day and drinking a couple beers, i was glad she was leaving me alone LOL
