Thread: Gauge problem
    Mar 2013
    Default Gauge problem
    Well I had my boat out for the first time after dark and when I turn on my nav. lights my fuel gauge pegs out on the full side, any suggestions
    2013 LSV
    2006 outback DD sold
    2004 Stingray 180LX sold
    Pensacola, FL
    That's better than being empty.
    Sorry, I am generally no help.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    Mar 2013
    : Pegged out full sounds great in theory but want get me very far
    2013 LSV
    Jul 2012
    Cumming Ga
    Sounds like you have a grounding / power issue on the gauge. It almost sounds like when you hit the switch its sending power to the signal wire for the gas tank level switch. I would make sure that you have solid grounds all the way back to the battery from your gauge. You can cause ground loops pretty easy in a boat if you don't have a solid ground.
