Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Apr 2009
    Raleigh, NC
    Default Air sucking sound/stall?
    Today was our first day out this year. The boat ran great for a few hours. We stopped for a bit to let the kids swim and have a snack. When I started it back up, there was a strange air sucking sound that seemed to be coming from the air intake - kind of like something was trying to suck in air but was restricted, or something that normally sucks in air but is muffled had the muffler removed. Also, if it didn't stall right after cranking, it would stall after giving it a little throttle. I took off the plastic cover and the flame arrester and tried cranking it. It made the same sound and wouldn't run long enough for me to go back to the engine after cranking it to inspect better. With it off, I opened the throttle all the way to make sure the valve inside was opening properly. Then, soon afterward (maybe the next crank) the sound was gone and it ran fine. I put things back together, and we probably ran for another 45 minutes or so without any problems.
    Any ideas what that sound could have been?
    Thanks.
    05 Mobius LSV - gravity 3 ballast and wake plate
    single axle trailer
    DIY hot water shower installed
    DIY tube inflator installed
    Jun 2009
    South West Colorado
    Vapor lock?
    Default Re: Air sucking sound/stall?
    Bilge pump?
    2006 Moomba Mobius LSV
    Only guy I've heard of lately complaining of too much sucking.
    Apr 2009
    Raleigh, NC
    It definitely was not the bilge pump.
    I've never had a vapor lock problem before. The lake and air temps were around 75, which makes me think that wasn't the problem. Can vapor lock cause that kind of sound? It was loud enough to be quite noticable.
    We took the boat out again yesterday and ran for 3-4 hours without any further problems.
    single axle trailer
    Quote Originally Posted by WolfpackRider View Post
    Maybe it was all the money being sucked out your wallet?
    Apr 2009
    Raleigh, NC
    Hmm, now that's a possibility. It's a good thing it stopped!
    single axle trailer
    Apr 2009
    Raleigh, NC
    We had the problem again today. I took a few videos. The first one was taken while the engine was running making the sound. I had the flame arrester off. So, it was a little louder, but not much. I had to have the throttle up quite a bit for it to run at all, though it only ran at an idle speed. A little into the video, the shot changes when I stepped back to lower the throttle at which point the sound got louder. Shortly after I stopped the video, it stalled.
    I also noticed that when I turned the key to the on position the fuel pump made a normal sound and then a louder sound right before it stopped. The second video is of the sound the fuel pump was making.
    (2nd video posted in followup post because the forum is only letting me post one at a time)
    After working with it for around an hour and letting it cool for that long, it finally ran normally again and did fine for the 7-8 minute ride back to the dock.
    So, could that have just been vapor lock, or should I be looking at something else like a fuel pump going bad?
    Thanks.
    single axle trailer
    Apr 2009
    Raleigh, NC
    2nd video of fuel pump:
    single axle trailer
    Mar 2013
    Madison, AL
    Might be bad gas from sitting up or the fuel filter has some trash in it. Could be why its a hit or miss on it.
    Try putting some stabil in the gas before you go out next time.
    2005 Moomba Mobius LSV
    ACME 1433 prop (newest upgrade)
    1900lbs Surf side
