Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Jan 2006
    Jacksonville, FL
    Default Kicker HLCD fell apart
    Just got down to the lake for memorial day weekend and heard something rattling in the speaker can so I removed it and this is what I found. What is this and can I use it without it for the weekend? I don't want to mess anything up. ImageUploadedByTapatalk1369437718.747934.jpgImageUploadedByTapatalk1369437732.163678.jpg
    Jan 2006
    Jacksonville, FL
    Dallas, TX
    Quote Originally Posted by 98outback View Post
    Both components (resistor and inductor) are glued to the circuit board AND the leads are soldered through the circuit board. That is the norm. So I don't find anything that I recognize as poor quality. In fact, the resistor weighs so little that it makes you wonder how both attachment methods failed. None of the leads came out. Instead the leads are broken off. But I'm not going to speculate what happened. None the less, it's an easy repair. The resistor will have to be replaced because the remaining leads are too short, but that is an easy resistor type, size and value to source. The coil can be slightly unwound without changing its value enough that it would make an audible difference. You just need enough lead to re-solder. Take a razor knife and scrape away enough enamel coating at the end of each inductor lead to get a good solder joint through the board. You'll need to desolder and remove the broken lead ends that still remain in the board. Be careful as to how much heat you apply specifically to the resistor. I would clean up and roughen up both board surfaces and the inductor surface and use a two-part epoxy. If you don't want to mess with it yourself, your dealer should be able to knock that repair out in short order. But, just to be safe I would check inside the other pod also before 'dropping it' off at your dealer.
    You can still play the midbass drive alone for the weekend. It won't sound its best but it will be safe. However, the tweeter must have the passive crossover or damage will result immediately. So definitely disconnect that.
    Nov 2009
    Stillwater, Oklahoma
    That shouldn't happen. Pm me Tuesday and let's get this fixed. Either repaired there or we can check on replace. As David says, it is an easy fix, but if we have to we can look at other options.
    Have a safe weekend-
    Phil
    Kicker
    Belton, Texas
    atta kid Phil!!
    2009 Moomba Mobius LSV
    Jan 2006
    Jacksonville, FL
    Thanks Phil. I looked at the inside of the can and could not find any signs of water in either side. I have not pulled out the other pod yet. Will do after the weekend. Thanks and have a safe memorial day weekend all.
    Gotta love these guys on here. Thanks, Phil!
    De Pere WI
    gotta love the vendors on the site...
    a big shout out to phil. lots of other vendors wouldn't stand behind the product that way..
    Agreed! We have some super audio friends on this forum.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Lake Amistad, TX
    Good stuff!!! Well, not that it happened of course, but that it's getting handled without question! Well done!
    2008 LSV Blue on White
