Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Jan 2006
    Jacksonville, FL
    Default New water impeller
    Quick question. I have heard that the impeller needs to be installed in the correct position but have never found any definite answer to this. So which end goes in first. The side that just says Johnson or the end with the dots? Or does it matter?
    ImageUploadedByTapatalk1369307901.764965.jpgImageUploadedByTapatalk1369307914.435630.jpg
    Oct 2010
    Winnipeg, Manitoba
    I think it's talking about which way the fins flex. When the impeller is installed in the housing the fins are bent. They need to be bent according to which way the pump turns.
    past---------------2003 Outback SOLD
    Ron
    Aug 2011
    Default Re: New water impeller
    Doesn't matter, when the pump turns the fins will automatically setup the correct direction..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Let's see if this helps. New johnson impeller user manual instructions.
    Sent from my SPH-L710 using Tapatalk 2
    Jan 2006
    Jacksonville, FL
    Thanks guys.
    Jan 2006
    Jacksonville, FL
    I did not receive any glycerine with mine. It came in a box with a gasket. I ordered it from skidim. Can I just put dish washing soap on it?
    Pensacola, FL
    I use anti-sieze compound on the shaft. Petroleum can damage the rubber if left on for a while.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    Jul 2002
    London Ontario Canada
    woooo hooo I see the vaseline no no is slowly spreading
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    It's so sad that Dusty has left the building as of late. There is so much potential with some of the posts above.
    I was just thinking the same thing earlier today...where has Dusty gone?
