Results 1 to 10 of 12
    St. Albert, Alberta, Canada
    Default Brake caliper stuck - weekend kiboshed - recommend checking these
    Brought the boat home from storage Thursday. Didn't notice any drag, but after a few miles, on a hunch, checked tire/rim temp. One was quite warm. Pulsed the brakes to see if that would release it. But jacked it up at home (another 10 miles) and very sticky; took effort to rotate the wheel.
    I checked Boatmate manuals online, and there is no specific periodic maintenance for calipers. Being in and out of the water twice a weekend when boat is used, I guess after 5 years these things can seize up.
    Dealer ordered in a caliper. I don't like the $449.00 bill to replace it, but I guess these must be specialized?
    Anyhow, I don't need any input, just a suggestion to stop after a few miles if you do haul it (I only haul mine twice/year) and check rim temp.
    Thus killed the May long weekend...(and a mighty whack to the wallet).
    '07 Outback V
    Ski|Board|Surf|Skate
    Default Re: Brake caliper stuck - weekend kiboshed - recommend checking these
    Dealer?!?! Autozone..
    2006 Moomba Mobius LSV
    Ya, electrically operated pressure release valve for backing up wasn't working either, so off to the dealer for both. That'll be a few additional bucks.
    '07 Outback V
    If I only towed a little ole OBV twice a year I'd be tempted to just remove the brakes.
    Dude! Go to pacifictrailers.com! 449 bucks is about 5 times too much! I just did all 4 calipers, rotors, bearings and all on my trailer for under 500 last year!
    Sent from my iPhone
    May 2013
    Raleigh, NC
    Everyone,
    I'm on the Supra forum too. . . BoatMate tech and support is great. THey have manuals posted and how-to's. .but my question is this. . these are supposed to be " relatively " maint free systems. Manual actuators etc.
    I maintain my brakes, but I'm a bit miffed at why after only a few years we're sinking some coin into the brake systems. I would think these calipers would be good for 10 years plus. Heck, my drag and race cars get better mileage.
    Aug 2008
    Cottage Grove, MN
    Sent from my iPhone
    X2 - individual parts aren't too expensive and fairly easy for someone like me who is not too mechanically inclined.
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
    Hey Supralauncher, tell us what all you do to maintain your brakes. Can't hurt.
    Tuscaloosa, Alabama
    I rebled my brakes and it took care of my problem.
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    May 2013
    Raleigh, NC
    Annual Maintence such as bleeding, lubricating the disc brake pad channels and replacing old fluid. The core problem with the lock up's that I've heard is that the piston dust boot doesn't keep debris out of the cyclinder wall, hence the piston doesn't retract and causing the brakes to be partially or fully engaged during transit. That's not an industry wide problem with brake calipers.
    I rebled mine twice and it did'nt full solve the issue until I took a c clamp ( doubled up the outer / inner brake pad ) and used the force of the c clamp to push the piston back into its recess position. I'm just worried that this was a temporary fix and that the next time I apply the brakes ( under hard braking ) that the problem will reoccur.
