Results 21 to 30 of 40
  1. #21
    Default Re: 2009 mobius lsv adding fat sac 750
    Quote Originally Posted by Boonejeepin View Post
    My boat requires the switch/blink trick.
    Not hard to do after the first time.
    What's the switch blink trick?
    Sent from my SCH-I545 using Tapatalk 2
    2009 moomba Mobius lsv
  2. #22
    Jul 2011
    Murrieta, CA
    Default 2009 mobius lsv adding fat sac 750
    I was referring to the process that jpetty posted.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
  3. #23
    That was confusing lol. Hopefully I can just program it with the perfect pass
  4. #24
    Quote Originally Posted by kregstrong View Post
    Nope. PP isn't tied to the ballast. They are independent systems. On a 2009, you have to follow the step petty posted.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  5. #25
    Dang there is seriously no other way to get the bags full?
  6. #26
    Sure, there are other ways - get a tsunami pump, throw it over the side and fill the bag. Unplug when its full.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
  7. #27
    Lake Amistad, TX
    Is this (reprograming the fill time) just an issue on the 2009+ models?
    Or will I need to do something like this on my 08 with the 1100lb bags??
    2008 LSV Blue on White
  8. #28
    Can I just keep flipping the switch to get it to fill or will it just quit and not go over 400 gallons?
  9. #29
    Quote Originally Posted by tgoody14 View Post
    If you have the Tsunami pumps then yes you have to do this untill 12 when Moomba went to the electronic dash displays. Then its as simple as going in the menu and changing your fill / drain time.
    If you have the standard areator pumps then no you wont change anything as these are not timed pumps
  10. #30
    Lake Amistad, TX
    Awesome, thanks Mike
