Results 11 to 20 of 40
  1. #11
    Nov 2003
    Land O Lakes, Florida
    plug and play with reversibles, reprogram the fill time to about 8 minutes before using and you should be just fine.
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
  2. #12
    There you go!
    Apr 2011
    Edmonton, AB Canada
    How do you reprogram the fill time?
  4. #14
    Jul 2011
    Murrieta, CA
    Default 2009 mobius lsv adding fat sac 750
    Quote Originally Posted by KEH View Post
    Do you have the Moomba EZ cruise or Moomba Digital Cruise Pro?
    If cruise pro:
    http://youtu.be/0b0Q1dhRqBU
    If not let me know. I have a document for the EZ Cruise style as well.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
  5. #15
    Apr 2011
    Edmonton, AB Canada
    2009 LSV so I'm pretty sure it's the Perfect Pass Wakeboard Pro
    Looks pretty similar to the one in the Youtube video but I am not near my boat to be able to confirm...
    Either way, who knew!
    All this time I have been cycling the darn switch...duh
  6. #16
    on 2009, I think it's a bit more complicated and there are some steps you have to go through with the switches they blink on/off to indicate what you're doing, etc. check the archives for your owner's manual and you may have to reach out to SC.
  7. #17
    Belton, Texas
    Very complicated IMO. So much so ive yet to do it
    2009 Ballast System Programming
    To change the fill time of the ballast:
    1. Connectbatterytothewiringwiththe60ampbreaker.
    2. Disconnectpowertotheballastcontrolboxbytrippingthe 60ampbreaker located by the battery.
    a. This will have to be done for programming each ballast control box. (Left rear ballast, Right rear ballast, and Front ballast)
    3. Resetthebreaker
    4. Within5secondsofresettingthebreaker;toggletheballa stswitch(ofthefilltime you want to change) FILL-OFF-DRAIN-OFF- FILL-OFF
    a. StopwiththeswitchtoggledtoFILL.
    b. Thiswillenterballastcontrolboxintoprogrammingmode.
    c. When the ballast control box goes into programming mode the
    pump will quit turning on.
    5. TheLEDontheballastswitchwillblinktoshowcurrentfill time.
    a. Whencountingblinkswaitforthesecondblinkcycleaftert he
    pause, blinking starts as soon as reprogramming has started and it
    is easy to miss the first few blinks.
    b. Refertothetimingcharttodeterminethecurrentfilltime basedon
    the number of blinks.
    6. ToADDTIMEtothefilltime
    a. To add 30 secs, turn ballast switch to FILL then OFF.
    b. NumberofblinkswillincreasebyoneeachtimetheFILL-OFFis
    toggled.
    c. Add remaining number of toggles of FILL - OFF to get the desired
    number of blinks from the timing chart.
    d. End with the switch toggled to FILL to count the blinks.
    7. ToREMOVETIMEfromthefilltime.
    a. Toremove30secs,turntoOFFthenDRAIN
    b. NumberofblinksdecreasesbyoneeachtimetheDRAIN-OFFis
    toggled.
    c. Add the remaining number of toggles of DRAIN - OFF to get the
    desired number of blinks from the timing chart.
    8. Whencountingblinkswaitforsecondblinkcycleafterthep ause,blinking starts as soon as reprogramming has started and it is easy to miss the first few.
    9. Whencorrectblinksareobtained,switchtoOFFandwait10s econdsto allow program to be set. This will now be stored in the AI unit.
    2009 Moomba Mobius LSV
  8. #18
    Belton, Texas
    TIMING CHART
    Blinks
    Time (minutes)
    Blinks
    Time (minutes)
    1
    2
    14
    8.5
    2
    2.5
    15
    9
    3
    3
    16
    9.5
    4
    3.5
    17
    10
    5
    4
    18
    10.5
    6
    4.5
    19
    11
    7
    5
    20
    11.5
    8
    5.5
    21
    12
    9
    6
    22
    12.5
    10
    6.5
    23
    13
    11
    7
    24
    13.5
    12
    7.5
    25
    14
    13
    8
    ETC
    20 max
    Rear bags All boats = 4.5 minutes of fill time = 6 blinks LS split tank = 2 minutes each side = 1 blink
    Front bags
    Moomba
    1) Outback V = 3 minutes of fill time = 3 blinks 2) LS / LSV = 3 minutes of fill time = 3 blinks 3) XLV = 4 minutes of fill time = 5 blinks
    Supra
    1) 20 SSV = 3 minutes of fill time = 3 blinks
    2) 21V=4minutesoffilltime=5blinks
    3) 22 SSV Walk-Thru = 3 minutes of fill time = 3 blinks 4) 22 SSV Play-pen = 4 minutes of fill time = 5 blinks 5) 24 SSV Walk-Thru = 3 minutes of fill time = 3 blinks 6) 24 SSV Play-pen = 11 minutes of fill time = 19 blinks
  9. #19
    Belton, Texas
  10. #20
    Jul 2011
    Murrieta, CA
    My boat requires the switch/blink trick.
    Not hard to do after the first time.
    2010 Moomba XLV
    340hp cat
    Rad-a-cage
