Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: screw lengths?
  1. #11
    Irondequoit Bay, NY
    Quote Originally Posted by maxpower220 View Post
    I think you should screw through the hull and use through bolts with thread locker. No one else is doing it and you will be unique.
    Use stainless screws.
    huuhhh..not. a. bad. ideeaaa.. lol
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
  2. #12
    Quote Originally Posted by motosno963 View Post
    the amp racks are already made, so what would the cutting board be used for
    you don't need it if you have the racks made. simply glue something to the hull (pressure treated wood or hpde blocks) and screw your amp rack to that.
  3. #13
    just make sure the screw head is on the outside and the nut is on the inside. for looks....
    2017 Moomba Mojo Max Surf Edition, 2 Pair Wetsounds Rev10s powered by an SD2, 6 paid Wetsounds XS650M and Wetsounds WS12 powered by SD6 all controlled by a WS420.
  4. #14
    Pensacola, FL
    That's just crazy, you look at the amp on the inside, the head on the inside. Nut on the outside.
    You are likely to get some bad advice on forums. Think it over before starting any project.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
  5. #15
    Irondequoit Bay, NY
    caan i rivit everything in? lol
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
  6. #16
    Jun 2009
    South West Colorado
    Default screw lengths?
    Sure, just make sure those rivets are stainless. You don't want anything to rust. That would suck...
    '08 Mobius LSV- SOLD!
    2017 Mojo Pro
  7. #17
    Jul 2010
    Vicksburg, MI
    Default Re: screw lengths?
    Also make sure that the center of the rivet doesn't pull all the way through. You will have a little hole to deal with.
    Sent from my Droid Charge using Tapatalk 2
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
  8. #18
    Jul 2010
    Vicksburg, MI
    Kidding aside, here is a link to the Supra forum showing the glued block method.
    http://www.supraboats.com/bbs/showth...?5519-Amp-Rack
    Joe
    2014 LSV
    1993 Echelon
  9. #19
    Irondequoit Bay, NY
    will look into it
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
