Results 11 to 20 of 26
  1. #11
    Jul 2012
    Cumming Ga
    Default Water leak thru prop shaft
    Well it was 550 for them to just install a new one. I actually already pulled off the v drive and everything. I just wanted them to install it and make sure it was aligned correctly so I'm guessing it would have been double that if I had them do the whole thing. I bought the 150 dollar part myself.
    This is why I value this forum so much. It's ridiculous what these places charge. The boat was literally done in 3 hours.
  2. #12
    Quote Originally Posted by chadjitsu1 View Post
    I just cant see my dealer charging that much for that repair. I have had much more work done for much less cost on my boat at my dealer
    edit: my dealer just quoted me far less than 750 for the part and labor
  3. #13
    Jul 2012
    Cumming Ga
    Me neither, oh wait ........
  4. #14
    Sep 2005
    Claytor Lake, VA
    Converted my 05 LSV to dripless. Over 400 hours later and still no drips. Tight working area but no need to remove the v-drive. I read where some installations fed the seal water supply off the manifold cooling line and had problems with the hot water causing the seal to expand and leak.
    2005 Mobius LSV
  5. #15
    Mar 2012
    Uniontown, oh
    Thanks. I'll try to tighten first. I'm torn between the dripless and the regular now. I'll wait till after Memorial Day since we are taking our almost 2 year old camping for the first time. He loves the boat. Lets just hope he loves a tent. Lol
    Nick
    2012 moomba mojo 2.5
    2005 Moomba outback-sold
  6. #16
    Jul 2002
    London Ontario Canada
    Quote Originally Posted by VA LSV View Post
    There are some good points in this thread. The vdrive does not have to be removed to install a dripless seal. What some mechanics say is aligned is not. They may be one of the most knowledgeable mechanics but if they consider a .005 unsymmetrical or multiposition tolerance as aligned there is a problem. Manuals state a symmetrical or single position .002 max tolerance so I fail to see why anything greater is acceptable. The seal on the dripless seals is fragile and can be nicked if not carefully installed. Plus a cool water supply is needed as well. They are great when working but a pain if not installed correctly. The packed seals are great as well and if installed well should yield a drop a minute or less, even they can be close to dripless. I would take it back if I spent 750 and it dripped. Something is wrong and wrong things usually don't get better. There is no breaking on the dripless seals they just get worse as you have already experienced.
    Va lsv, it's the seal housing they expands with the heat not the seal
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
  7. #17
    so im pretty sure my dripless shaft cooling line comes from the hoses between the exhaust manifolds, it sounds like yall are saying this is wrong so here are my two questions, why would they design it wrong from the factory and where should it be tied in at?
  8. #18
    Jul 2011
    Murrieta, CA
    Theoretically the cooking line would tie into the raw water hose.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
  9. #19
    that just seems odd those because until that line gets to the impeller isnt it under a vacuum kind of?
  10. #20
    Sep 2005
    Claytor Lake, VA
    The kit included a 1x1x3/8 tee with instructions to install in the line before the manifolds.
    And yes it is the housing that expands due to the water temp.
    I would also take it back if I paid someone to install it and it still leaked.
    2005 Mobius LSV
