Results 1 to 10 of 10
    May 2013
    South MS
    Default Water hook up for servicing
    Does anyone know how to hook up a water supply to a 2003 direct drive outback ls? I'm trying to work some kinks out and don't want to drive the hour to the lake.
    Portland Oregon
    So many ways, here is mine:
    Loosen the hose clamp where the fresh water intake hose attaches to the through hull OR the stainer, stick your garden hose in the black rubber pipe going towards your engine, turn in your hose and start your boat.
    Make sure you have adequate water supply, I regulate mine with a plastic ball valve made for garden hoses, the $2.00 one.
    -Jake
    Sep 2010
    Camp on pool 8 of Allegheny River (Adrian, PA)
    Use the "fake a Lake" and a garden hose. Lookes loke the old school toilet plunger with a garden hose connection. The plunger end fits over the water intake under the boat.
    2003 Outback
    Boat name = Lynn Syndrome
    Its a condition that runs in the family...Judy Lynn (mother-in-law) Heather Lynn (wife) & Megan Lynn (daughter)...no known cure...but the boat helps
    New boat for me on 10/9/10.
    Do a search on "plunger" and you will see how to make one for about $8.
    Is there such a thing as a new school plunger?
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Aug 2009
    Montana
    $8 bucks is about right!
    bought me a "fake-a-lake" plunger about 4 years ago and found that my home-made one works alot better. Never could get the plunger to seal right on the hull!
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
    Aug 2008
    Cottage Grove, MN
    Here's what I use. Just connect it to where the water intake goes into your vdrive.
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
    Irondequoit Bay, NY
    i do this now..only because my perko flush adapter in the boat broke over the last winter
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Oct 2008
    Central, Arkansas
    Quote Originally Posted by mnpracing View Post
    Same setup used for over 5 yrs on 3 boats..
    Mar 2008
    Vancouver WA
    Default Re: Water hook up for servicing
    Pretty much what I use/do. I just cut off a 2" section of my intake hose (I had extra) and clamp it to a 1 1/4" barbed by 3/4" thread with a hose thread adapter.
    Slip the intake hose off, slide and clamp the adapter on... easy.
    Sent from my iPhone 5... ya right!
    PWI as usual...
