Results 1 to 10 of 14
    Mar 2008
    Default 06 supreme with scorpion 5.7 won't start. Ideas?
    Working on a the boat mentioned above and won't start.
    Had the starter bench tested and its dead. Installed a new one and and still won't start.
    I'm positive its not the neutral safety switch because when I turn the key over I hear a click in the back.
    When the the throttle in ingaged the click from the back stops.
    I know the starter is good because I can jump the starter to start the boat.
    The click is coming from a relay located above the v-drive next to a reset button I'm assuming for a engine or ecm fault. Its not tripped.
    Thoughts?
    Sent from my iPhone 5... ya right!
    PWI as usual...
    Mar 2008
    And no its not the safety lanyard. The relay in the back doesnt click when I unplug the lanyard.
    PWI as usual...
    Irondequoit Bay, NY
    dead relay?
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Mar 2008
    Default Re: 06 supreme with scorpion 5.7 won't start. Ideas?
    dead relay?
    Fixed it, it was the slave cylinder... you guys suck lol
    PWI as usual...
    Hey, check the slave cylinder. Oh, crap. You found it. Oh well.
    Mar 2008
    Yea thanks!
    PWI as usual...
    Oct 2005
    Durham, NC
    So just to be clear, the throttle lever was in neutral, but the slave cylinder on the transmission was keeping the boat from actually being in neutral, therefore the neutral safety switch wouldn't let the boat start?
    Brian Roberts
    2001 Outback DD
    Mar 2008
    Not a "trans slave cylinder" its a solenoid/relay that when you turn the key it sends power to the slave cylinder and in turn sends power to the starter. Boat shop said its a commonly replaced part.
    Mounted to the trans bell housing.
    PWI as usual...
    Mar 2008
    Unless your being a smart ass then yes... the clutch needed to be bled too!
    PWI as usual...
    Mar 2008
    Here's a better pic for anyone that may run into the same problem.
    PWI as usual...
