Results 11 to 20 of 29
  1. #11
    Portland Oregon
    Default kenwood KMR-700u
    Quote Originally Posted by motosno963 View Post
    you like it?
    I do, I've smoked a few iPods over the years so having it inside the deck is great. Even the iPod I use now has a display you can't read due to water damage but the display and search on the deck is one of the easiest I've used.
    I put the brain in the spotters cubby close to my amps which also let me use shorter Rca's.
    -Jake
  2. #12
    Portland Oregon
    Btw, I got a refurbed one on eBay for about $180
    -Jake
  3. #13
    Irondequoit Bay, NY
    nice..i might pick one up
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
  4. #14
    The one i had in the LSV i liked very much also. I also had the matching remote wiht the display on it. The controls on the stereo are easy to use and read. The remote is slightly different but not to bad at all.
  5. #15
    Irondequoit Bay, NY
    ok..i think i might order it
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
  6. #16
    De Pere WI
    keep in mind the 700u won't work with older wired remotes. you have to replace them as well.
  7. #17
    Feb 2010
    Canton, Ga / Lake Lanier
    From what I understand the 107 remotes have been discontinued and replaced with a round style remote. May still be able to find some left over stock around though...
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
  8. #18
    De Pere WI
    could be and would not surprise as round seems to be the standard, but just know the older kenwood stuff won't work at all with the 700u.
  9. #19
    Irondequoit Bay, NY
    yeaaa i figured..just sucks that they made the old remote oval and the dash formed to it..i would replace that remote with a new one but i domnt think kenwood makes oval remotes anymore
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
  10. #20
    De Pere WI
    the 107remote square one is slightly larger than the oval iirc. it should look ok installed. if not, use a piece of the black mounting plastic that car audio guys use and build a larger cover. I know when I mounted it to the transom of the supra it covered up the fade/wax lines that were present from removing the old remote.
