Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Irondequoit Bay, NY
    Default kenwood KMR-700u
    well im going to upgrade the head unit in the boat, i want to get the KMR-700u but i cant find the measurements for the face..i know the main body will fit im just worried about the face hitting the bottom of the compartment and the radio not fitting
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Tooele UT....
    kenwood's website will have the faceplate dimensions and possibly crutchfield. it's a very large faceplate vertically and not as wide as a normal face horizontally iirc. it's pretty thick and needs some space under the face to open all the way.
    very solid hu and tons of adjustment potential. I liked it a lot better than the clarion unit in my boat.
    Irondequoit Bay, NY
    you have the 700 in your boat?
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Feb 2010
    Canton, Ga / Lake Lanier
    Isn't it a 2 part radio similar to the factory MB Quart unit? Has the face where you put the iPod but then the main part is separate and mounted elsewhere. Maybe I'm wrong but I thought I saw a pic of it like that.
    I have the 550U which is great too! I think there is a new model that replaced that one though.
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Irondequoit Bay, NY
    yeaaa its two parts
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    It is a 2 peace but not quite like that.
    It has the brain part seperate but it does actually look like a normal stereo head unit, the face plate is larger then normal for the controls and display. It then has the case of a normal stereo and within that your Iphone plugs in and goes in side, or a thumb drive so its water tight.
    Feb 2010
    Right, that's what I meant. I was just using the MBQ as a reference to the separate brain. The separate brain is actually what turned me off from using the 700. That's just one more thing to mount the way I looked at it.
    Tow Rig:
    Irondequoit Bay, NY
    either the 700u or this one.. the kenwood KIV-701..we never use cds so this is another reason
    http://www.sonicelectronix.com/item_...d-KIV-701.html
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Portland Oregon
    -Jake
    Irondequoit Bay, NY
    you like it?
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
