    Jul 2009
    Guntersville AL
    Default Water Removal in V-Drive
    What is the best way to remove and flush the oil in the V-Drive if it has water in it? I know how the water got in there just gotta get rid of all that milky oil in there and was wondering what was the best way.
    Thanks Matt
    Jun 2010
    Lake Houston
    Default Re: Water Removal in V-Drive
    Suck it out with a pela or equivalent vacuum pump.
    2013 LSV
    2005 LSV - SOLD
    Portland Oregon
    There's a drain plug on the bottom, drain and refill. I used a pan with only about a 1" lip so I could slide it under the unit. Plus some disposable rags. Mine was full of water on pre-purchase inspection and I drained and filled it just so I could do a test drive. I changed it after every use for the first four or five uses, it would get cleaner each time, and it's been perfect ever since.
    -Jake
    Irondequoit Bay, NY
    might have to drain it and fill it once or twice to make sure its all out
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
